Raspy
- Joined
 - Dec 16, 2006
- Messages
 - 1,656
- Location
 - Smith Valley, Nevada
- Tractor
 - NH TC29DA, F250 Tremor, Jeep Rubicon
My favorite is the blue board insulation.  Whatever you use be confident that it will not absorb water and that is is worthy to support your slab for the life of the building.  The bubble foil stuff commonly put under slabs is, in my opinion, a waste of time and money
I approach the heat loss in a couple of ways. One is to hold the heat back from the perimeter. It is not necessary or desiraeable to heat right up to the edge of a room except at entry doors. I don't want any insulation out in the middle of the room under the slab. No heat loss there unles there is air or water movement. Edge insulation is best inside the perimeter footing.
Local codes and local conditions call out specific needs. Just make sure what you do makes sense.
I know that's vague, but there are a lot of ways to do this and a lot of theories.
