HP Requirements Different for Lift/Pull Cutter. WHY?
   / HP Requirements Different for Lift/Pull Cutter. WHY? #1
rutwad
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
Just looking at the specs on a Bush Hog 307 7' rotary cutter and the HP requirements for lift type is 60 and pull type is 40. Why would the HP needs vary?
   / HP Requirements Different for Lift/Pull Cutter. WHY? #2
Manufacturers also take into consideration the possible weight of the items when recommending horsepowers for the use of the machine.
I wouldn't want one of those on the back three point of any 40 engine horsepower tractor that I can think of even those that boast of their great weight!
For safe operation it still isn't enough even with a loader and a bucket full on a hill!
Yeah, I can understand weight or size needed for the tractor. Seems like the cutter manufacture would make some recommendation other than HP since you can get pretty good HP in such small tractors now. I don't think it's 60, but can you imagine the 7' lift type behind something like a JD 4720..:confused:
   / HP Requirements Different for Lift/Pull Cutter. WHY? #4
I was talking with a fella over the weekend and he said a Kubota dealer told him with a front snowblower you need a minimum of 39hp.????
I guess my question is....Does a mid-pto or front-pto transfer less hp than a rear pto.??
I told the guy that the dealer is full of crap.
(sorry to hijack, though it is sort of the same) Carry on.
   / HP Requirements Different for Lift/Pull Cutter. WHY? #5
One of my neighbors has a 4720 cab and an MX7 cutter. I tried it out one day this summer and it felt stable, kind of suprized me too. I think I can manuever better than he can but most of his property is all bottomland.
   / HP Requirements Different for Lift/Pull Cutter. WHY? #6
Basically...you're right...dealer is probably full of it. There is a degree of power loss, of course, as it would be with any transmission of power.
Now, that guy you were talking to may have left out one very important factor...the size of the blower. Something like an 8' front blower may require considerable horsepower.
As far as the power requirements for a cutter...a 30 PTO HP tractor may run a 7 or 8 foot cutter...might not be able to lift it though. A 40 PTO HP tractor, being larger and heavier (probably) then that 30 HP machine may lift cutters that size easily. That's just an example with arbitrary cutter widths, so we don't need dozens of replies stating how easily their 30 PTO HP tractor lifts those size cutters.
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2018 Allmand Light tower (A49461)
2018 Allmand Light...
2018 Nissan Versa Sedan (A48082)
2018 Nissan Versa...
1274 (A50490)
1274 (A50490)
