3320 Height / Width
/ 3320 Height / Width #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
Ive located a 3320 open station that I plan to look at next week. Sounds to be what I have been looking for...at a fair price. It has the "larger" R4 tires on it. (43x16-20 4pr rears)
I beleive these tires will provide 60" width....which is fine. Can anyone tell me how high this tractor will be at the ROPS? I have an 8 foot door height....and prefer to not drop the ROPS when coming and going.
( Also, I am a little surprised the bigger R4 tires carry a 4 ply rating vs a 6 ply for the less expensive tires. Duh! )
/ 3320 Height / Width #2
Take a look at the operator's manual (for the 3320) link on the Deere website. The Specifications section near the end of the manual provides quite a bit of dimensional data. You may find what you want there...
/ 3320 Height / Width #3
Two things. the dimensions of the 3320 are :
59.5" for the large R4 tires in the narrow position. (I just measured this.)
92.5" (according to Deere) for the ROPS height.
My 3320 fits under my 8 foot door (just barely). The door in the up position is less than 96". I adjusted the door springs to lift the door as high as possible. Anyway it does fit.
As for the large R4 tires. I originally ordered them with my tractor but changed my mind. I tried to switch to the smaller R4's but it was too late. I'm glad in the end that I got the bigger tires. They fit the tractor better and the tread will wear out long before the 4 plies die. The smaller R4's have a higher weight limit in the back but a lower one in the front.
If you look at the Deere pamphlets they show the 3320 with the larger tires in all the pics. You also get better traction with the larger tires. They show the smaller R4's on the 'economy' tractors in the 3000 line.
Rob
/ 3320 Height / Width #4
I had zero issues with my old open station 3720 with the larger R4's and my home 8' garage door. I could even fit under the spot where the garage door opener attached the garage door with room to spare.
Thanks for the responses. On the way home from "up north" today.....I stopped by a good John Deere store. They had a used (but beat up) 3320 and a new 3320 parked side by side.
The new one had the larger tire size and the used had the smaller tires. I measured the taller tire unit to the top of the ROPS.....93" dead on. :thumbsup: Also measured the width....and can see where the wide wheel setting will go to about 60"....just as shown in the owner manual that Roy pointed out.
Sometimes I just gotta see for myself in order to be comfortable. :eek: I learned long ago....verify everything. ;)
I really like the looks of the bigger R4 tires and when sitting in the 3320 seat the tractor feels like everything should be just as stable as my current ride - or better.
I'm going for a look at a real nice used 3320 early next week. It appears that the tractor has everything I'm looking for....with just 200 hours use. :) If I get this deal done....I will provide some more details...and the obligatory picture.
/ 3320 Height / Width #6
Lookin' forward to your report back.. And those pics when the time comes!!
Best of luck.
AKfish
/ 3320 Height / Width #7
Not just for looks, but I feel the tread design on the larger R4's aka Galaxy Marathoner...is a superior tread. This is my first tractor with R4's and all those reports about R4's being slippery in snow, balling up with mud, etc.. have been proven to be completely false to me. I'd buy these tires again any day.
/ 3320 Height / Width #8
Dave, I think you are having good luck with them due to the weight you added. In the winter you not only have your iron weight, but also a rear snow blower.
I do not have any weight on mine other than a ballast box and I don't like them for snow. With weight, they might be better......
/ 3320 Height / Width #9
That might be the case...BUT when the blower is on the ground and in operation, I'm down to just 220lbs additional weight, I wouldnt think that 220 lbs would make them go from skates to real tires.....
Like I said, this is my first machine with R4's....Deere made the decision easy for me...Turfs are not for me, and the R1's look super chinsy on a machine of this caliber. For my intended use, I was steering towards R4's anyways...
/ 3320 Height / Width #10
The larger R4's are for better traction, ask a dealer or JD.
Rob
/ 3320 Height / Width #11
I agree with what you said, but I am not typing very clear. I think that adding any weight to these tires helps them alot. It forces them to flex more and get more to the ground. The larger R4's are very flat tires and the bars are very thick. With my snow push and a ballast box my large R4's do as well as the turf tires on our 4110. On concrete, if you spin, they turn the snow to ice and you are screwed. They do not dig because they are so flat. If I drop the snow push, I get more wieght in the back and I can get them to do better. The weight helps.
I agree, the R1's on the 3x20, and even the 4x20's dont look cool, but they do get more traction to the ground. On both my 3720 I put R4's, so I do not disagree with you that I would get R4's on this tractor again.
Rob
I never said that they did not nor did I even compare the smaller ones tot he larger R4's. I had/have the large R4's on both 3720 that I had/have.
/ 3320 Height / Width #12
I guess what I am saying in to many words is; If you don't put weight on them they can suck. People having issues with them in snow might not be weighted correctly for the implement they are using. I know I am not with the 3720.
At one time I figured I could not live without R1 tires....as I thought I needed all the traction I could get for pulling a disc and a plow. Turns out I don't use my plow due to sandy soils (don't want to turn sand up). Now I mostly use my tiller....so the hard "ground-engaging" work is reduced. Then too....my soils are mostly a sandy-loam.....so I'm generally not working in a greasy environment with 'em. (My ground is dry a few hours after a hard rain.) Snow use is not needed here.
Also my disc is smaller sized (5.5' box frame) and with the extra weight of the 20 series I figure these R4's should out perform my 790 with R1's.....which is all I need. The extra toughness of the R4's (over R1's) on my wooded property should be a good thing.
Sooo....I'm hoping these new tires are the deal for me.
/ 3320 Height / Width #14
Hate to sound "vain" but it wouldnt have killed Deere to put larger/meaty R1's on the option list...I know its purely a cosmetic thing, but stilll...
When you see a Kubota with R1's it looks like a real tractor, They actually got nice rubber...a 3x Deere with R1's looks odd....
DPA042.aspx
/ 3320 Height / Width #15
R4 or R1, not overinflating the tires makes a huge difference in traction. My parents' 3320 Cab model will easily spin the wheels with rear R1 pressures of 13 psi, but not with 10.5 psi. Same with the 3038E I just bought with R4s. I had worried about traction because of all the power in such a light package with the 3038E, but at 10.5 psi in the rear tires, grip is very good. Neither tractor has iron wheel weights or liquid fill.
/ 3320 Height / Width #16
That's a weight distribution problem not a tire problem. All tractors should have proper ballast regardless of the tires.
Rob
/ 3320 Height / Width #18
The procedure put forth by Goodyear in their AG handbook is basically to weigh the tractor at each axle; ballast your tractor front or rear such that a MFWD tractor has 35 - 45% of weight over the front wheel with all attachments added; then lower the tire pressures to the minimum necessary to support each axle per their inflation and ground speed tables. They don't recommend liquid fill, and seem to suggest that even iron weights may be avoided in many cases with this procedure, unless needed to bring the axle percentage into balance.
This is what I have tried to do with our tractors, and so far it works, though I have yet to try them with heavy ground engagement attachments like a plough.
/ 3320 Height / Width #19
My R4's make mine look like a "real tractor" to me:
I agree! I love my R4s.
I do wish Kubota had options in the R4 choice. I had 4 different tire/wheel size options and like 8 or 9 choices if you include bias/radial/steel/cast varieties.
When you choose R4, you get one option. One size, steel wheel. My "big bad M8540" actually looks fairly small when you put the shorty R4s on it! The short R4s combined with a folded down ROPS and a "down exhaust", my tractor looks like a low rider!
/ 3320 Height / Width #20
Rob
For the tire work right, it has to be weighted correctly. I don't want to use the word most, but many people do not ballast thier machine correctly and it leads to compaints about tires and traction. That was my only point.
These tractors should, but do they?
TANK MANIFOLD (A58216)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Kubota U55-4 (A57148)
1459 (A57192)
1459 (A57192)
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
