Compression tester
   / Compression tester #11
rpete,
With 5000 hours and excessive black smoke under load, I would expect that you need to have the injectors checked or overhauled.
Is the engine going through more than normal amounts of oil? This would be more of a bluish smoke anyway.
rpete,
It uses no oil. I have changed oil and filter every 100 hours for it's life. Never overheated, hot but never close to red line. I am hopeful I do not have to remove anything beyond injectors and a compression test will help me decide.
   / Compression tester #13
Have you checked your air filters? Has it lost power or just smoking black. I have changed injectors on a high hour engine before and it improved power and stopped the smoking. If you continue to run with a bad injector you could get cylinder wash and score a cylinder.
Dan
Dan
I think I will take your lead and just get a new set of injectors and see what happens. Probably a good time to check compression while changing injectors anyway. If I do have a mechanical problem beyond injectors, I most likely will tear down and rebuild and would want to install the new injectors anyhow. Darn, $$$.
2022 CATERPILLAR 259D3 SKID STEER (A50458)
2022 CATERPILLAR...
2003 Ford F-350 Pickup Truck, VIN # 1FDWW36P63EC81092 (A48836)
2003 Ford F-350...
1980 Carley Dump Trailer (A48836)
1980 Carley Dump...
2021 Ford Explorer SUV (A48082)
2021 Ford Explorer...
2012 Kenworth T800 Truck, VIN # 1XKDDP9X3CJ300455 (A48836)
2012 Kenworth T800...
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
