Compression tester
   / Compression tester #11
rpete,
With 5000 hours and excessive black smoke under load, I would expect that you need to have the injectors checked or overhauled.
Is the engine going through more than normal amounts of oil? This would be more of a bluish smoke anyway.
rpete,
It uses no oil. I have changed oil and filter every 100 hours for it's life. Never overheated, hot but never close to red line. I am hopeful I do not have to remove anything beyond injectors and a compression test will help me decide.
   / Compression tester #13
Have you checked your air filters? Has it lost power or just smoking black. I have changed injectors on a high hour engine before and it improved power and stopped the smoking. If you continue to run with a bad injector you could get cylinder wash and score a cylinder.
Dan
Dan
I think I will take your lead and just get a new set of injectors and see what happens. Probably a good time to check compression while changing injectors anyway. If I do have a mechanical problem beyond injectors, I most likely will tear down and rebuild and would want to install the new injectors anyhow. Darn, $$$.
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2020 Freightliner Cascadia 126 T/A Sleeper Cab Truck Tractor (A49461)
2020 Freightliner...
RoGator RG1100C (A51039)
RoGator RG1100C...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
