FEL Cutting edge - direction?
   / FEL Cutting edge - direction? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I am planning on welding a new cutting edge on my old FEL bucket. I got a used edge from a town plow and cut it to length. That is all great, but I can't decide which direction to place the cutting edge bevel.
Common convention seems to put the sharp edge facing down with the bevel on top, but that seems like that would put undue stress on the sharpened edge, especially while back-dragging (I do a lot of that) - with any downward angle at all on the bucket, all of the load stress is across the thinned metal of the sharpened edge. Putting the flat side up with the bevel on the bottom would allow the sharpened edge to be supported back into the blade, and would allow both pushing and backdragging with a bucket angle as high as the bevel w/o stressing the sharpened edge.
90% of what I do with my tractor is dozing, grading, and back-dragging rocky soil and/or gravel. Is upsidedown (bevel down) maybe a good idea? Are my edge-stress theories valid? I can't decide what to do.
Thanks - JayC
   / FEL Cutting edge - direction? #2
My tractor came with a bolt on cutting edge and it was beveled down. It has worked well for me, but I have never tried it any other way.
   / FEL Cutting edge - direction? #3
I believe it is just plain common sense to put the bevel on top. If there is a standard, it is probably bevel on top. In back dragging or pushing, you are going to wear out the lip of the blade, either direction.
Bevel on top, flat side to bottom.
   / FEL Cutting edge - direction? #4
The bevel on an implement blade is basically the same as a wood chisel...
granted once welded on it can not be flipped but the principal is the same...
When using a chisel the flat side is usually used to make the initial cuts then the bevel side (down) is used to remove (scoop out) the material...
   / FEL Cutting edge - direction? #5
A Picture!:thumbsup:
   / FEL Cutting edge - direction? #6
Just some pictures for clarification. Bevel on top
Thanks all - The pictures are very helpful. I suspected that the "normal" way to mount the edge is bevel up. However, I looked at several old weld-on cutting edges, including my own and on a big backhoe down the street, and the entire bevel area is worn off. On these old edges, the bottom of the cutting edge is scraped away so that the top is flat and the bottom is curved up to the top, making the sharp edge on the top. An upsidedown edge would mimic this profile.
I read that one of the things you should do to keep an edge good is to avoid backdragging. In my case, I do a lot of backdragging with my FEL - probably 60% of my run time is in reverse with my front wheels in the air. It seemed that putting the edge on upsidedown would help avoid breaking the tip off of the edge during backdragging.
JayC
   / FEL Cutting edge - direction? #8
You may find that the old grader blade cutting edge is quite a bit different than what came with the bucket.:D
It should last much longer. Don't worry about backblading.:D
   / FEL Cutting edge - direction? #9
Bevel edge should be on top. With the bevel edge down, it will continually force the bucket up as you dig.
   / FEL Cutting edge - direction? #10
If I understand you correctly it would seem to me it comes down to the strength of the weld.
Put a good weld on it and I would think you could beat on it for many years, or hours for that matter.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56438)
2016 RAM 5500...
2009 Wilson Hopper Bottom (A59814)
2009 Wilson Hopper...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 JCB 930 (A53317)
Pintle Hitch Triple Axle Trailer - NO TITLE (A59814)
Pintle Hitch...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
