2305 diverter valve slop
   / 2305 diverter valve slop #1
diz
Rochester, NY
I've had a diverter valve hooked up on my 2305 since fall. When I use it now, in mower independent lift position, the deck goes up and down but the bucket curls slightly as well. I don't remember this from last fall, maybe I hooked something up wrong this spring, or maybe that valve is getting sloppy. Anyone see this? Thanks!
In case anyone else has this problem and is looking for info, here's a thread I found through google where two others are reporting exactly the same behavior of that valve. I liked the diverter valve at first, but wouldn't buy it again based upon the way it's behaving now. Maybe I'll try to take apart the valve body and see if I can figure out anything inside there.
http://www.mytractorforum.com/showthread.php?p=769380
   / 2305 diverter valve slop #3
You know, I have had the diverter valve for I think 2 seasons on my 2305. (I got it so I can leave my Woods BH6000 backhoe on when mowing, although I rarely do that).
Just the last time I mowed my deck kept doing that but I attributed it to having my guide wheels too low for the height I was mowing - I figured when I turned and hit them it pushed the deck up slightly.
I'll have to watch it next time. It is quite possible that I didn't have the valve seated all the way. Also my curl circuit always moves slightly when I'm putting the deck up/down with the diverter on.
   / 2305 diverter valve slop #4
My Diverter Valve does the same thing, only not just slightly, it's very noticeable. When I have it set for using the mower deck, the bucket still curls/dumps. When I have it set to the loader, the mower deck still raises/lowers. Also, if I use the quick dump position on the stick, the deck jumps up and down.
I brought it into the dealer to have them look at it while it was still under warranty and they shrugged it off and gave me a bill for wasting their time. Nice, eh?
Awesome (not).
That just makes me want to take that valve body apart even more. If it's going to be that sloppy, I won't bother even reinstalling it.
   / 2305 diverter valve slop #6
What diverter valve do you guys have? Any id or specs on it?
   / 2305 diverter valve slop #7
I don't have the part #'s handy but it goes on the right fender and it diverts the Curl
Circuit of the Dual SCV to the hydraulic Cylinder on the mower lift (Or I suppose anything else you wanted). I only got it so I could mow with my backhoe installed. Prior to having it (The 2305 is a 2005) I was perfectly happy with the mechanical 3pt deck lift. I remove the arms when I mount the BH so that isn't an option with the BH.
   / 2305 diverter valve slop #8
Can someone post a picture please? Is there a linkage to the diverter valve?
If you click the link to that thread on another forum, up a few posts, there's a PDF in there that contains drawings of the whole assembly.
   / 2305 diverter valve slop #10
Found it on the jdparts under alphabetic listing "diverter valve" too.
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
2002 Olympian D90P1 96kW Diesel Generator (A52377)
2002 Olympian...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A54757)
UNUSED RAYTREE...
