TalonDancer
Gold Member
- Joined
- Jul 29, 2007
- Messages
- 388
GL3240 Update -- 3yrs & 600 hrs (pics added)
We just celebrated our GL3240's 3rd birthday w/ 600 hrs on the clock
This has without doubt been the most trouble free and valuable investment we've made a very long time.
Some of you old timers may remember our L3240's first major project when we excavated and processed nearly 200 tons of limestone, etc. building a pad for our two 10,000 gals rain water storage tanks.
Last year we built a 3 bay garage with attached carport in front of the tanks. In addition to unloading and moving literally tons of building materials on the job site (e.g. cement blocks, concrete, lumber, HardiePlank, pavers, etc.), the 3240 with the pallet fork...
* lifted and placed several large beams including a pre-assembled 24'x16"x5.5' LVL onto 9' cripples (AKA jack studs) and a 24'x16"x3.5"GLULAM into metal saddles over 9' high. BTW the 9' clearance allows the 3240 to go anywhere in the structure with the ROPS and sun shade up
* lifted all the 4'x8'x3/4" roof decking
* lifted all of the metal roofing to just above eve height (over 9') for easy installation.
Various other projects include:
* excavating an 8' diameter x 8' deep hole for the 5' diameter spherical water catchment tank.
* spreading and boxblading 80 tons of road base for the construction driveway
* spreading a boxblading 40 tons of road base for a neighbor (who had loaned me scaffolding during the garage construction)
This year as the 600 hrs ticked over, I had just completed the 320 ft of ditch for the under ground power. This project required excavating over 60 tons of alluvial fill, transporting the soil w/ the smaller rocks to the future house site, transporting pallets of the larger "river rocks" for future use and backfilling the ditch with over 60 tons of manufactured sand (a utility Co. requirement).
So our L3240 has been a little busy these last 3 years. During most of this time she has been configured as a TLB with either the loader bucket or pallet fork. I would not own a loader without quick attach. I only put the box blade on for specific projects. As a TLB the L3240 is perfectly balanced WITHOUT water in the tires. When I have the box blade on she can get a little light in the rear with 3/4 ton on the pallet fork. The answer is NOT water, it's weight on the box blade.
I really, really like the HST plus with the on the fly (Turtle-Rabbit) settings for each of the 3 main "gears". I can't remember the last time I used Low, and only use Medium when carrying a heavy load up a grade. I use High (Turtle) 80-90% of the time.
I run exclusively in Auto-Throttle mode, adjusted as I've posted previously. When starting up from a dead stop with a heavy (e.g. 1/2-3/4 ton) load I use the hand throttle to increase the RPM (read HST pump output) for the power steering, etc. and quickly push it back once underway.
I've done all the maintenance myself. It's a bit messy but pretty easy. Kubota could have made the HST and Hydraulic filters easier to replace at the 200 and 600 hr points. But once you know how, it can be done without much mess or loss of HST fluid.
The ONLY thing I wish I had done differently is to buy the 3540. The 3240 is a little under powered when used hard. But I really like the size, so I would not go any larger.
Talon Dancer
Talon Dancer
