kubota hydraulics messed up
   / kubota hydraulics messed up #1
r l jones
kubota l 3400
i have a l 3400 kubota tractor.the hydraulic is mested up.front lift and p t o skip and jerk going up.power steering is hard to turn.front loader will not go down with motor off.4 years old.the higher the r.p.m. the better it works.
   / kubota hydraulics messed up #2
Welcome to TBN.
Do not continue to operate the machine with the hydraulics starving for flow especially if it is an HST (hydrostatic Transmission) it will be destructive.
It sounds as though you have a hydraulic restriction.
Since it effects even the power steering I would look to the strainer (if it has one) filters and fluid first.
Have you checked the fluid and what does it look like?
How long has it been since you changed the fluid and filters?
   / kubota hydraulics messed up #3
Check Quick connects to be sure they are connected properly.....seems like return line restriction if FEL does not go down.....also check to make sure your 3-point/draft control is not in "Full Up Position"....this will sometimes make the same condition.....
Good Luck.....:)
   / kubota hydraulics messed up #4
Check the fluid to see if it's foamy or milky looking.
   / kubota hydraulics messed up #5
Pull the HST filter under the HST pedal and see if there are lots of shavings there...
I would also not run it until figured out at all..
When was the last time you changed your HST filters and fluid?
J
changed fluid and filters after this stared liked 10 hours being time to change them.fluid does foam when it is running.
   / kubota hydraulics messed up #7
Sounds like a hyd suction leak. Check the input hose to the pump.
   / kubota hydraulics messed up #8
thanks j.j. i think you mit have hit it.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
ERIE INDUSTRIES GF480 ROTARY DRUM SCREEN (A57193)
ERIE INDUSTRIES...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
