Another "myth to kill"??.....what makes it go???
   / Another "myth to kill"??.....what makes it go??? #11
Area is implicit of course.
   / Another "myth to kill"??.....what makes it go??? #12
I will say yes. Of course pressure is needed to overcome the load. If I remember right, a pumps job is to produce flow primarily, and pressure is secondary.
Pressure that has no flow= no work, but potential work.
   / Another "myth to kill"??.....what makes it go??? #13
If the river is flowing the Ram pump may be pumping as well as waterwheels turning various equipment.:D
But mainly it seems to be the state of the energy and it's application.:thumbsup:
hint#2....
How can objects (a load) move where there is no "flow" available???
   / Another "myth to kill"??.....what makes it go??? #15
hint#2....
They can't.
Brian
edit- Back to the original question. Flow alone can make it go as long as as there is no resistance or load.
   / Another "myth to kill"??.....what makes it go??? #16
hint#2....
Parasitic, weight, and leakage.(or a damned good magician!)
They can't.
Brian
yes objects can move with out flow.....it happens all the time...my wheel barrel moves without hydraulic flow....and so do everything else that moves from just a force....
read Newtons first law again.....only force is required to move an object....
   / Another "myth to kill"??.....what makes it go??? #18
If no flow, then no go. You could have pressure, you could have volume, but if the fluid is not moving, you have a static situation, such as an accumulator. The potential for work is there. A weighted load is another way to push fluid, and could exceed the pressure of a pump. When you ram that bucket into a dirt pile or a stump, the back pressure could exceed the pressure rating of any component in the hyd system.
   / Another "myth to kill"??.....what makes it go??? #19
hint#2....
I thought we were talking hydraulics here.
{ Wheel barrel } ?
   / Another "myth to kill"??.....what makes it go??? #20
Depends on how "Slippery the Slope" is!:thumbsup:
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
John Deere 853 20ft Corn Head (A56438)
John Deere 853...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
