Another "myth to kill"??.....what makes it go???
   / Another "myth to kill"??.....what makes it go??? #11
Area is implicit of course.
   / Another "myth to kill"??.....what makes it go??? #12
I will say yes. Of course pressure is needed to overcome the load. If I remember right, a pumps job is to produce flow primarily, and pressure is secondary.
Pressure that has no flow= no work, but potential work.
   / Another "myth to kill"??.....what makes it go??? #13
If the river is flowing the Ram pump may be pumping as well as waterwheels turning various equipment.:D
But mainly it seems to be the state of the energy and it's application.:thumbsup:
hint#2....
How can objects (a load) move where there is no "flow" available???
   / Another "myth to kill"??.....what makes it go??? #15
hint#2....
They can't.
Brian
edit- Back to the original question. Flow alone can make it go as long as as there is no resistance or load.
   / Another "myth to kill"??.....what makes it go??? #16
hint#2....
Parasitic, weight, and leakage.(or a damned good magician!)
They can't.
Brian
yes objects can move with out flow.....it happens all the time...my wheel barrel moves without hydraulic flow....and so do everything else that moves from just a force....
read Newtons first law again.....only force is required to move an object....
   / Another "myth to kill"??.....what makes it go??? #18
If no flow, then no go. You could have pressure, you could have volume, but if the fluid is not moving, you have a static situation, such as an accumulator. The potential for work is there. A weighted load is another way to push fluid, and could exceed the pressure of a pump. When you ram that bucket into a dirt pile or a stump, the back pressure could exceed the pressure rating of any component in the hyd system.
   / Another "myth to kill"??.....what makes it go??? #19
hint#2....
I thought we were talking hydraulics here.
{ Wheel barrel } ?
   / Another "myth to kill"??.....what makes it go??? #20
Depends on how "Slippery the Slope" is!:thumbsup:
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
9000 (A47477)
9000 (A47477)
ASSET DESCRIPTIONS & CONDITION (A59575)
ASSET DESCRIPTIONS...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
