Bucket empties by itself!
   / Bucket empties by itself! #1
comfun1
Kubota B7100
The bucket on my loader will empty by itself unless I hit the joystick every 10 seconds or so. It has gradually been getting worse. It is a B7100 kubota and I bought it new in '92. Any idea how to tell what is wrong?
   / Bucket empties by itself! #2
i just had the same thing happen to mine, when i brought it to the dealer ship they told me that a nut that holds the packing in had come loose causing fluid to bypass. I'm sure there are other causes but that was mine. here is a link to what some others told me that it might also be.
good luck.
http://www.tractorbynet.com/forums/hydraulics/174922-bucket-leaks-fast.html
   / Bucket empties by itself! #3
Cylinders leaking, or valve leaking. You could switch hoses between the lift and curl and see if the problem switches.
   / Bucket empties by itself! #4
Hey JJ, how is every thing around the Florida area? It"s fine here around the old Clinton area, except very hot and humid. zman:thumbsup:
   / Bucket empties by itself! #5
very good start on trouble shooting...:thumbsup:
question:single or two bucket cylinders...
   / Bucket empties by itself! #6
Some machines have one curl cyl, but most tractor have two. I have one curl cyl on my Power-Trac.
   / Bucket empties by itself! #7
What kind of condition is the Joystick control system in?:confused:
   / Bucket empties by itself! #8
I was up in Clinton about two months ago for the Thornwell reunion , and it was hot. About the same here in Jacksonville, with 95 degrees.
Until three years ago, I was working in this kind of heat all day using weed whackers, backpack blowers, etc. Retired now, and with all the drugs they have me taking, I can only tolerate the sun for a couple of hours, and then I call it a day. It's h**l to get old, but someone has to do it. What I don't like about these golden years, is that everyone is taking all my golden dollars.
   / Bucket empties by itself! #9
could just be a split or cracked O-ring in the loader valve.
   / Bucket empties by itself! #10
Generally, there are no o-rings in a spool valve. The sealing is done by very close tolerances between the spool and the bore in the valve body. They are are a lapped/honed fit-that is why you cannot buy a replacement spool.
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
1350 (A47477)
1350 (A47477)
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2015 CATERPILLAR RM300 ROAD RECLAIMER (A52705)
2015 CATERPILLAR...
