Bucket empties by itself!
   / Bucket empties by itself! #1
comfun1
Kubota B7100
The bucket on my loader will empty by itself unless I hit the joystick every 10 seconds or so. It has gradually been getting worse. It is a B7100 kubota and I bought it new in '92. Any idea how to tell what is wrong?
   / Bucket empties by itself! #2
i just had the same thing happen to mine, when i brought it to the dealer ship they told me that a nut that holds the packing in had come loose causing fluid to bypass. I'm sure there are other causes but that was mine. here is a link to what some others told me that it might also be.
good luck.
http://www.tractorbynet.com/forums/hydraulics/174922-bucket-leaks-fast.html
   / Bucket empties by itself! #3
Cylinders leaking, or valve leaking. You could switch hoses between the lift and curl and see if the problem switches.
   / Bucket empties by itself! #4
Hey JJ, how is every thing around the Florida area? It"s fine here around the old Clinton area, except very hot and humid. zman:thumbsup:
   / Bucket empties by itself! #5
very good start on trouble shooting...:thumbsup:
question:single or two bucket cylinders...
   / Bucket empties by itself! #6
Some machines have one curl cyl, but most tractor have two. I have one curl cyl on my Power-Trac.
   / Bucket empties by itself! #7
What kind of condition is the Joystick control system in?:confused:
   / Bucket empties by itself! #8
I was up in Clinton about two months ago for the Thornwell reunion , and it was hot. About the same here in Jacksonville, with 95 degrees.
Until three years ago, I was working in this kind of heat all day using weed whackers, backpack blowers, etc. Retired now, and with all the drugs they have me taking, I can only tolerate the sun for a couple of hours, and then I call it a day. It's h**l to get old, but someone has to do it. What I don't like about these golden years, is that everyone is taking all my golden dollars.
   / Bucket empties by itself! #9
could just be a split or cracked O-ring in the loader valve.
   / Bucket empties by itself! #10
Generally, there are no o-rings in a spool valve. The sealing is done by very close tolerances between the spool and the bore in the valve body. They are are a lapped/honed fit-that is why you cannot buy a replacement spool.
2016 BOBCAT S850 SKID STEER (A52705)
2016 BOBCAT S850...
2004 Ford F-250 (A55788)
2004 Ford F-250...
2012 CATERPILLAR 259B3 SKID STEER (A52705)
2012 CATERPILLAR...
UNUSED LANDHONOR LHR-WS22 WEBBING SLINGS (A54757)
UNUSED LANDHONOR...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
