J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,973
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
That is exactly what I said.
Originally Posted by J_J
Would not a properly designed electric valve system have a relief valve before the electric valves?
here is the electric over hydraulic valve that I have and I do not have any problems feathering the grapple on the loader
MD3
Do you have a diverter valve and are you using the joystick to operate the grapple? If so, you should be able to feather the hyd operation.
Is this something you want to do, or have done?
No I do not have a diverter valve. I have a bank of 4 electric valves on a manifold. This 4 bank valve set-up came off of a truck crane. I also have a JD 400 series backhoe (power beyond) . It would seem like the most economical way for me to add 4 sets of hydraulic ports in the rear. I also found a few items in a box marked port meter in-flow. I think that the port meters would take the place of you needle valves suggestion J_J right???
JD4600 is open center, 2500 psi, 10.3 GPM.
