Haytech Grapple - need to adapt to my JD 40)X and JD 542
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542
I am sure you got a good deal ... I am leaning towards the Rafter M grapple ... will build my own accumlator, for the FEL ...
$3500 for the accumulator and grapple.
I need to replace some springs and modify the grapple.
I have plenty of winter projects. I need to get that grapple ready to go.
I better get a working baler also. :)
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #12
Is the accumulator the pull behind the baler or the FEL mount?
I got an e-mail from ATI today and talked to hay tech. ATI makes a plate for Hay Tech that supports both of my loaders. I can buy it directly from Hay Tech. Cool deal eh?
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #15
Well thats good ... isn't it?
It is in my mind. I need to get after cutting off that old mount.
I figured I would let people know - the ATI guys make all kinds of stuff.
D.
Plate came in
I hope the hardware is coming in a separate box.
Looks like it only support the 500, not the 400 loader.
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #18
Plate came in
D.
All you need to do is add a second set of pins to fit your other loader, the top hooks are the same.
I hope you didn't pay to much for that?
Right can add another set of pins. I am going to see how it feels on my 5525 tractor. I have the thumb switch for the 3rd valve, so I think I will be using it, but who knows.
Probably paid too much, but my time is worth something. It is well done.
D.
   / Haytech Grapple - need to adapt to my JD 40)X and JD 542 #20
Worksaver makes front loader mounting brackets that can be bolted or welded. If you go to their website worksaver.com. Under the tab Product line is a category for Optional Front Loader Brackets (for Worksaver Implements). The #831640 fits the John Deere 400X loader.
They are a bit spendy. I think around $350 but it would be another option.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
John Deere 1018 10ft Rotary Cutter (A51573)
John Deere 1018...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2018 CATERPILLAR 318FL EXCAVATOR (A51246)
2018 CATERPILLAR...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
