Brake Cleaner & HEAT = VERY DANGEROUS !!!
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #11
is this limited to brake cleaner.. or apply to carb cleaner too?
I tend to use the two interchangeably when I'm at the store buying it.. I do weld too.. though no mig so no argon..
soundguy
The bad ingredient is chlorine and bonds with the hydrocarbons in the cleaner. Read the label before use.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #12
Can't even hardly get the chlorinated kind around me anymore. It work good for seating tires when I didn't have ether.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #13
Sometimes I'm amazed I'm still alive.
A younger and dumber self may have intentionally blasted brake cleaner past a lit torch for a little flamethrower effect.
Or it could have been a dream, not sure. :ashamed:
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #14
I've found another good use for it, It will kill bees almost on contact. When you spray their nest, most of the time they can't even fly, they just drop and die. Really potent stuff.
Max
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #15
My parts washer usually has diesel in it. sometimes other things I won't list in the safety section.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #16
Many parts washers have Stoddard solvent in them. It is also known as white spirit. Also was used for dry cleaning.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #18
Max
foamy engine brite works darn good too! :)
soundguy
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #19
soundguy
We don't use anything "Chlorinated" because of this phosgene issue and we do not want any to accidentally mix in with our waste oil that is used in our waste oil furnace....that being said, we use regular carb spray for degreasing all the time......
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #20
Yup the brake cleaner I pick up at WalMart doesn't have the phosgene causing chemical in it...but a name brand that is more expensive right next to it does. I also buy their carb cleaner but reserve it for tougher jobs on something it won't damage, I've had it attack some plastics and paint. Which can be a good thing if thats what you want:thumbsup:
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2015 Nissan Altima Sedan (A50324)
2015 Nissan Altima...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
