Brake Cleaner & HEAT = VERY DANGEROUS !!!
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #11
is this limited to brake cleaner.. or apply to carb cleaner too?
I tend to use the two interchangeably when I'm at the store buying it.. I do weld too.. though no mig so no argon..
soundguy
The bad ingredient is chlorine and bonds with the hydrocarbons in the cleaner. Read the label before use.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #12
Can't even hardly get the chlorinated kind around me anymore. It work good for seating tires when I didn't have ether.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #13
Sometimes I'm amazed I'm still alive.
A younger and dumber self may have intentionally blasted brake cleaner past a lit torch for a little flamethrower effect.
Or it could have been a dream, not sure. :ashamed:
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #14
I've found another good use for it, It will kill bees almost on contact. When you spray their nest, most of the time they can't even fly, they just drop and die. Really potent stuff.
Max
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #15
My parts washer usually has diesel in it. sometimes other things I won't list in the safety section.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #16
Many parts washers have Stoddard solvent in them. It is also known as white spirit. Also was used for dry cleaning.
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #18
Max
foamy engine brite works darn good too! :)
soundguy
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #19
soundguy
We don't use anything "Chlorinated" because of this phosgene issue and we do not want any to accidentally mix in with our waste oil that is used in our waste oil furnace....that being said, we use regular carb spray for degreasing all the time......
   / Brake Cleaner & HEAT = VERY DANGEROUS !!! #20
Yup the brake cleaner I pick up at WalMart doesn't have the phosgene causing chemical in it...but a name brand that is more expensive right next to it does. I also buy their carb cleaner but reserve it for tougher jobs on something it won't damage, I've had it attack some plastics and paint. Which can be a good thing if thats what you want:thumbsup:
2006 Ford Expedition 4x4 SUV (A50324)
2006 Ford...
2014 Chevrolet Equinox 2LT SUV (A50324)
2014 Chevrolet...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
