Backing up a trailer
   / Backing up a trailer #41
one more thing that jumps to mind...
dont move around too much in your seat.
You have these people which are first looking in the center mirror, then one side mirror, then the other then turning around in their seat and finally put their head out of the driver window....
The situation will look different from every angle and you will end up correcting your corrections ending up in a ditch which you didnt see because your were moving more than looking.
If the trailer can go there (and that you'll see from outside the vehicle walking around) it will go from any position, choose one and stick to it.
I'm not a pro at all but have to reverse my horsebox from street to 90 degrees double Z curved driveway through my gate with 6 inches spare on both sides of the wheelarches and van-mirrors and further aligning to the horizontal jacked driveway (so you dont see where the downside slope goes) to my horsebarn. All this over 450ft with a 35ft van-trailer combination. Mirrors only and without stopping or forward driving is how it goes now, but it took me a whole library of cursing before i got there.
practice makes perfect.
:thumbsup:
   / Backing up a trailer #43
When I bought my ride it came w/ the trailer in my sig.
I live on a moderately narrow dead end court, about 27' wide.
My tow vehicle is a 20' Ford Maxivan.
My trailer is 24'.
I went and bought a 3pt hitch trailer mover.
I used to (40 years ago) drive a 5 ton pulling a trailer w/ a hot kettle for roofing tar and equipment. 40 years ago I could back that thing like it was part of my body. Didn't want to go thru the learning experience again.
   / Backing up a trailer #44
   / Backing up a trailer #45
One of the common mistakes I see people make in backing a trailer, is not having the trailer wheels in the right place too start with, especially when turning from an angle to where you want to back. Usually this is from not being far enough ahead, and then having to turn way too sharp to try to get the trailer in the proper place. I prefer to back on a turn, easier to see the trailer if backing with the truck. hard to describe.
   / Backing up a trailer #46
I agree pulling forward a little further to get the rig lined up good is key. I consider myself pretty good at backing a trailer but I still get my wires crossed once in a while - if I think about it too much.:)
I still can't back a wagon worth $%^&. The farmer I worked for back in HS could back the tractor-chopper-wagon rig indefinitely. (He did have power steering) He could also back a full wagon uphill into the barn loft with a pickup with a topper.
   / Backing up a trailer #47
multiplying the length of the tongue will expoentially make it easier to steer in reverse...
   / Backing up a trailer #48
I've been moving trailers for over 30 years. Usually in a vehicle which requires using the mirrors. No sweat any more. Now take away my mirrors so I have to look over my shoulder...different story.:laughing: The worst I ever had to back was a 5 yard dump truck with a short narrow air compressor. By the time you could see it, it was already too late.:D Had to back it 1/2 mile off a bridge we were building.
As many have already said, extend the tongue of the trailer. The longer the distance from the ball to the center of the axles, the slower it will react and the easier it will be to back. Beyond that, it's all just practice.
   / Backing up a trailer #49
Turn Into The Drift
Thats my little memory tool to help me get it right.
Once the trailer starts to drift off line, turn in that direction to straighten out.
Go really slow, just creeping. Do lots of "stop and pull up" to recorrect. Once you lose it and it starting to go way off line, dont crank the wheel and try to catch it- stop and pull up 10'.
If you'r backing into a garage bay it helps to paint lines on the floor and driveway. A little 3" paint roller works great.
   / Backing up a trailer #50
Also you can buy a Quick-Connect receiver that goes on your front bucket. It clamps on with a pinch bolt.
Should be easy on/off.
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
