I have issues paying $12 for headlamp bulb
   / I have issues paying $12 for headlamp bulb #1
imjillerma
kubota b1750
The headlamp bulb for B1750 is a quirky little thing that it would appear Kubota has a monopoly on and want to charge $12 each.
Anybody know where these can be purchased at a reasonable price?
Thanks...I love this site! :)
   / I have issues paying $12 for headlamp bulb #2
I agree that $12 seems high enough for a bulb, but then again, our truck and car both take a halogen twist in bulb that costs that much too. One Ford, one Honda. If it were $30, I'd likely scream. $12? I dunno. If I couldn't find a replacement, over the counter type, and needed to run the lights to work at night? I'd likely just buy one and move on. Hope you find a more economical solution.
   / I have issues paying $12 for headlamp bulb #3
Look at the base of the bulb. Stamped in the base may be a number. That is what I used for mine and found it at Wal-mart for much less.
Deano
   / I have issues paying $12 for headlamp bulb #4
How about $300 for a thermostat for a Newer model Ford CHA Tractor. Just heard about that last night. Dealer sent a service man out and 3 hrs. later he had it in. Total bill, parts and labor $900. Kicker is that it did not fix the problem. Ken Sweet
   / I have issues paying $12 for headlamp bulb #5
For $12 a bulb, maybe you should just check into an LED replacement.
They can be pricey, but they should last allot longer.
And in my B7800 the LED replacments were brighter than the stock headlight bulbs.
LEDs draw less current too.
   / I have issues paying $12 for headlamp bulb #6
Don't buy a Volkswagen if you are twitchy about expensive bulbs... one Touareg headlight bulb = $280 Cdn. I'd sooner be in the dark !
Sean
   / I have issues paying $12 for headlamp bulb #7
Paid $18.50 for a head light bulb for L2800. Sent nasty e-mail to dealer and he refunded me $3.00. Still to much for a bulb the size of a flash light bulb.
   / I have issues paying $12 for headlamp bulb #8
Just out od curosity, what does your dealer charge for his shop labor? Ken Sweet
   / I have issues paying $12 for headlamp bulb #9
The high beam filaments are burned out in my Outlander. About $25 each. I just run it on low beams.
   / I have issues paying $12 for headlamp bulb #10
Well now, let's be fair here... a Touareg HID (Bi-Xenon) bulb from the dealer might be $280 Cdn. But the same OE Sylvania replacements are also available for less than half that on the aftermarket.
Non-HID VW's pretty much use the same typical bulbs as everyone else, with a few "european type" bulbs here & there. ;)
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59575)
2021 CHEVROLET LCF...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
