Verticaltrx
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I'm not very familiar with the L series, but do they have an external hydraulic line that runs to the 3pt hitch cylinder like the B-series does? If so, a very simple fix in my mind would be to install an adjustable flow regulator. It could be left in the open position for max flow when doing tasks such as bush hogging or discing where you want a quick lift, then turn it down to a lower flow setting when you want more control, such as box blading. Surplus center sells various types of flow regulators, not very expensive either.
My old Ford NAA has a 3pt hitch that's a little bit jerky as the result of too much flow to the 3pt cylinder. It has a replacement hydraulic pump on it which has a higher GPM than the original pump. Also, the original pump had a little flow restrictor knob right on the pump so you could dial up or down the flow rate depending on the job.
