which bucket ...
   / which bucket ...
does anyone know the width on the front from the outside of the front tires...will the 49" cover the width of the front end..?.....my dealer said he doesn't recommend the larger bucket on the smaller tractors but will check to see if he has one in stock....
   / which bucket ... #12
Used to be the narrower bucket was the heavier duty. Also had a heavier cutting edge on it.
The price difference indicates that may be the case here too. I'm glad I went with the heavy duty, but then I don't move lightweight material like snow and sawdust. Just a thought.
edit: There were only two buckets available 11 yrs ago when I purchased the JD 4300. Today may be different as to what is HD and what is not.
   / which bucket ... #13
size has nothing to do with the heavy duty....they make a heavy duty version of various sizes....for example there is a 61" standard bucket. or the 61" hd which has side gussets, a boxed in top, and a heavy cutting edge with holes for a bolt on edge....
i don't know how small they make the heavy duty in, but the standard buckets are all standard. from 49-73inch. i've seen them all in person, no differences.
   / which bucket ... #14
just talked to the dealer and he said he would recommend staying with the 49 because of the added stress the 53 would cause to the front axle ...:confused:
Get the 53". With a properly filled ballast box (you are getting one?) front axle loading is not a concern.
   / which bucket ... #15
My 2210 handled the 53 really well. I usually wished it had a bigger bucket.
I could even dig with the 53 on it. You have alot bigger tractor, but the same power.
   / which bucket ... #16
Your dealer is probably "recommending" the smaller bucket because the larger bucket is more popular and he (or Deere) has a boat-load of them they want to get rid of. I suspect your dealer's recommendation is self-serving and not based on capability of the machine. If potential damage to the machine is a possibility, then why is it even an option? Why aren't they telling you that by putting the larger bucket on, you will void your warranty because it's not recommened? I say it's just your dealer's personal opinion on the matter.
   / which bucket ... #18
You will only regret getting the 53" because you could have had the 61".
My dealer suggested the 53" over the 49" on my 2520. After a year of pushing snow and moving firewood I wish I would have ordered the 61".
   / which bucket ...
well guys...the dealer said he didn't have the 53" in stock so I didnt want to wait for him to order one and went ahead and stuck with the 49"....I think it"ll be enough bucket for the kind of things I'll need it for...they got the FEL installed today and I went and looked at the 49" and it was actually bigger then I thought...it does cover the whole front end and sticks out past each front tire....:)
   / which bucket ... #20
You are seriously going to kick yourself for this in the near future. If you decide to upgrade to a bigger bucket, you will be out a LOT of cash. Don't rush, and make the dealer get the bucket you want. :confused2:
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2017 CATERPILLAR 307E2 EXCAVATOR (A51246)
2017 CATERPILLAR...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2007 Mack Winch Truck (A53117)
2007 Mack Winch...
