pfrankovich
One of the front steering boots is slightly torn on my BX2350. How big of a deal is this? It doesn't look as if its filled with grease or anything. It looks like it would be difficult to replace it.
Mine tore and I replaced them both with bicycle inner tube.... It does not take long to replace the boots with tube (30mins per side once you get the hang of it)..... I used a mountain bike tube 2.125 size. When you cut it make it long enough so that you can turn the tube inside out over itself to make it twice as thick and then secure each end anchoring it with zip ties straddling the joint...
Things to pay attention to:
1. The length of your tie rods (measure the length of the tie rods BEFORE you begin removing them (measure twice to make sure you put it back together very close to original)
2. DO clean the tie-rod joint (you dont have to get crazy with the cleaning, just do a good job) then manually try to regrease the joint with a good quality grease (I use a lithium based axle grease)
I will post pics when I get a moment, and I may post a "how to" next time I change them (they usually last a year before I have to replace them)....
