What's a good way to scoop up large stones?
   / What's a good way to scoop up large stones? #21
Went out and scooped this one. The one next to it was a bit too large for the tractor.
That's a good illustration of how the throat opening (distance from the leading edge to the back of the bucket) on your loader buddy is a lot different than a standard utility bucket. The OP can buy one, but you aren't comparing apples to apples. Good sales technique though :) Do they come with a grapple arm(s) too?
Dave.
   / What's a good way to scoop up large stones? #22
For rocks laying on or close to the surface I use my bucket and grapple or the chain method or I pry them into the bucket with a 5' bar. I keep the bar handy in the FEL torque tube. You have to be flexible and use what works. No two rocks are the same. My grapple helps alot to hold the ones that wont actually fit into the bucket.
It is the ones that are half buried that give me trouble. Those I have to swear at.
I have a 6' hexagonal bar, point on one end, chisel on the other. I call it my 'Maine Toothpick'. :laughing: Use it just like you describe for stubborn rocks.
Dave.
   / What's a good way to scoop up large stones? #23
As Magicheater showed in his video(and others have stated), it's all in the technique.
If you watch his 'technique', you'll notice that he knows his machine, and the bucket.
Practice, practice, practice.....learn the machine, that's the key.
Another little tip to remember......most of the time, all ya gotta do is get about 1/3 of the total weight off the ground in order to move something, IE: reverse and drag.
1 more tip that people overlook, usually the 3 point will have twice the lifting capacity of the FEL........use that to your advantage:)
   / What's a good way to scoop up large stones? #24
Yep - I take my carry all, drop it off, roll the rock on it, throw a strap around the BIG rock, then re-attach it to the tractor and drive away. Plus then I can put a few others in the front bucket - makes a great counter weight....
   / What's a good way to scoop up large stones? #25
FWIW....on stubborn rocks.....a tire chain makes a good "net" or web to put behind a rock/boulder.....and pull it with a chain hooked to the drawbar.
   / What's a good way to scoop up large stones? #26
I use a manure bucket. It looks like the loader buddy but it does not have steel webbing between the tines. The thing is handy as all get out for just about everything, rocks of all sizes, logs, hay, straw, brush, even pallets.
   / What's a good way to scoop up large stones? #27
Mine sorta looks like this pic.
   / What's a good way to scoop up large stones? #28
I use my pallet forks. For the really large rocks, I mount them on the three-point hitch.
   / What's a good way to scoop up large stones? #29
Runner
That looks like a great way to move rocks. And with the HTL, you can even dig them out.
I've used my forks for rocks too, and have one now that the FEL won't lift that I plan to move soon with the forks on the 3 ph. It is a big flat one that I've only been able to skoot out of the way for now.
   / What's a good way to scoop up large stones? #30
I use a rock bucket on my 110 for smaller stuff and use forks for large rock and stumps.
Here's the rock bucket on the 110.
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
GMC C8500 CHASSIS TRUCK (A54756)
GMC C8500 CHASSIS...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
2018 KENWORTH W900 DAY CAB (A53843)
2018 KENWORTH W900...
2019 PETERBILT 579 (A53843)
2019 PETERBILT 579...
