STEERING WHEEL POSITION
   / STEERING WHEEL POSITION #1
glc24
Southwestern, Pa.
Hey guys,
Why does the position of my steering knob keep changing on my 2520?
When I first mounted it,it was on the bottom at 6 o' clock. Now it's everywhere but there.
It's driving me crazy.:confused2:
Greg
   / STEERING WHEEL POSITION #2
That is the nature of the beast. Any tractor that uses the "hydrostatic" type of power steering suffers from steering wheel "drift". The steering valve depends on a "metal-to-metal" fit which allows some leakage internally. It is considered excessive leakage if you turn the steering wheel to a full left or right turn and keep pressure on the steering wheel. If the wheel continues to turn at a rate of more than 3 revolutions per minute, it is excessive and the steering valve should be replaced.
Thanks for the insight jd110.:)
It doesn't move much, sometimes it's at 9 o'clock,and sometimes at 3,but it's hardly ever at 6 anymore.:(
Greg
   / STEERING WHEEL POSITION #4
I have an X495 and notice that the wheel will continue to turn once you reach the normal end of the steering travel in either direction. I have read also that this is "normal" with hydrostatic power steering, as there is no mechanical "stop" in the system.
I just kinda watch it on sharp turns and don't try to push it past the limit. I've had no problems, but when it first happened I too thought there was something wrong with the steering.
I just got a new 2520 as well, and assume it will be the same.
REV
   / STEERING WHEEL POSITION #5
Yup, perfectly normal...That is one of the reasons I do not have a spinner.
I think I'm just going to remove it. If it's not going stay at the bottom of the wheel,then I don't want it.:mad:
Greg
   / STEERING WHEEL POSITION #7
Greg
I understand. With the effortless steering on these tractors you really don't need it anyway IMHO.
   / STEERING WHEEL POSITION #8
Greg
I have a lot of trimming to do when mowing so I left mine on. Sometimes I have to hunt for it but I am used to doing that now and will keep it on untill it wears out.
   / STEERING WHEEL POSITION #9
I added a steering knob knowing it would move all around, decided to try it anyway, & I'm just fine with it. When driving dead straight, if the knob's not in a good position, I just hold the wheel instead. If I'm turning all around a lot, then it doesn't really matter where the knob is, it works out fine at any place. It's definitely not necessary for my hydrostatic power steering, but ... I kinda like it.
   / STEERING WHEEL POSITION #10
With my 5210 I also find that the knob ends up in different positions sometimes, but it is still very useful for steering left handed while operating the joystick for the FEL or when feathering implement height.
Weren't these things called suicide knobs when they were used on cars in the "old days" when you steered left handed while your right arm was around your special passenger ;)
Not that I would be old enough or ever act that way behind the wheel...
   / STEERING WHEEL POSITION #11
My wheel turns so easily that I just use the flat of my hand.
Rob
   / STEERING WHEEL POSITION #12
Yep...slightly before my time, but I like old movies. I'd see them in a fair number of cars from the 1950's.
   / STEERING WHEEL POSITION #13
:thumbsup:
The spinner position on my L4350 Kubota moves but stays within about a 90 degree position. My left hand is on it almost constantly and my right hand is on the joystick. Generally I can get the wheels turned from hard side to side before the shuttle shift engages fully. Something I would not be able to do with out it. Handy when you are really working the tractor and not dallying around.
For some reason the spinner on my B7800 seems to stay put, or with in a 10-20 degree arc.
This is one of the first things I do when I get a tractor without one.
Forgot about the FEL. I never did mind the position of the spinner while using the joystick. It's just cutting grass and going straight for long distances has me thinking of where the spinner (suicide knob:)) ends up.
Maybe I'll leave it alone after all.:)
   / STEERING WHEEL POSITION #15
:thumbsup:
thats what ive always been told. It drove me crazy at first too but youll get used to it. :thumbsup:
   / STEERING WHEEL POSITION #16
"Weren't these things called suicide knobs when they were used on cars in the "old days" when you steered left handed while your right arm was around your special passenger "
Yup, or necker's knobs....
I just spin my wheel with a finger in the spoke. Wish the steering on my Ford truck was this easy....
   / STEERING WHEEL POSITION #17
That reminds me of a funny story. When I was a kid and first got my license I wanted to impress my girl friend. I was driving my mom's De Soto (a big tank of a car) with one hand on the wheel and one arm around my girl friend who was half in my lap. I came to a 90 degree turn with no stop sign and couldn't negotiate the turn fully. About half way through it I panicked and grabbed the wheel with both hands womping my X girl friend's head against the wheel! It wasn't pretty... I could have used a spinner!
Rob
   / STEERING WHEEL POSITION #18
Rob
That's a good one Rob. I had a good laugh picturing your girfriend as you whacked her head on the steering wheel. I guess your "coolness" factor dropped pretty quick that night.
REV
   / STEERING WHEEL POSITION #20
REV
Things went bad fast after that and the next day in school she had to, OF COURSE, tell everyone what happened!
Rob
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
John Deere 6110M (A53317)
John Deere 6110M...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
1453 (A57192)
1453 (A57192)
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
