starting problems
   / starting problems #1
papavillars
Member
I have a m4900 diesel. When I tried to start it today it started but reved up very fast (like it wanted to run away) and then died. It would not start after that. I checked the fuel filter bowl and it was full. I finally cranked it for about thirty seconds and it finally started. Any one else have this happen?
   / starting problems #2
diesel issues
Is the decompression on this diesel automatic or is it not equipped with the automatic decompression?
Does it have an ether can screwed into the air inlet?
It honestly sounds like you had a lot fuel in the heads and it took off until it settled down with the idle speed.
   / starting problems
leonz, it does not have the ether and it did not settle down and idle but died and took about twelve times to start at fifteen seconds per try. I finally held it for thirty seconds and it started.
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2014 International Derrick Digger Truck (A55973)
2014 International...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
