Need Help lighting for new garage
   / Need Help lighting for new garage #1
scrivy69
Member
Missouri
2010 JD 2320
I know this probably has been asked many times before. But I need some help deciding the best and cheapest route on lights for a 30'x30' garage with a 10' ceiling. I have an electrician coming saturday to wire the garage. He asked me yesterday what i was going to use for ceiling lights? well I dont know:confused: so I thought i would ask members their experience and ask for suggestions. We are going to either Lowes or Menards to check out what they offer. Also how many would you all use. My initial thought was to use 4 foot 2 bulb flouresants with electronic ballast. 3 each on the 7 trusses (21 total). Just a thought, Just like everybody on a budget i thought I would chime in to see what the members have in their particular shops. Thanks for any help in advance.
   / Need Help lighting for new garage #2
4' double-bulb fluorescent fixtures spaced no more than 5 or 6 feet apart.
Use at least 2 switches. One controls every other fixture, & the other controls the remaining every-other-fixtures. This way, if you don't need full lighting, you can turn on just half of them & still light the place pretty well.
   / Need Help lighting for new garage #3
Shop and do you're math. instead of that many 4 foot, you will do well with 8 or 9-8 foot flourescents. Not only are 4 footers notorious for burning tubes quicker, the light output from 2-4 foot fixtures will not equal 1-8 foot with a high output ballast. HO's (high output, with zero degree ballasts) are a little more expensive but in the long run, less maintence. For example i light my shop with 6 of them, (24 x 32) and its more than enough light for most things and in 15 years i have not replaced a ballast, and have only replaced 2 tubes.
Location of tools, work bench's etc, will determine lighting layout, though a good rule of thumb would be a row of 3 about 6 feet from each side wall, this lights benches well without lights glaring in you're face, and a row of two or three down the middle. Switch them according to you're bench layout\work habits.
As a retired master electrician, i've laid out and installed literally hundreds of buildings of all shapes and sizes, so balanced lighting is not a new thing to me. If you wish, contact me via pm and i'll have you email me a proposed layout, i'll work up a lighting diagram that should work for you.
   / Need Help lighting for new garage #4
This is based on the well-lit office I'm sitting in right now, but sized up for your 30' x 30' garage:
(Edit: It's actually 640W on the green circuit, & 560W on the red circuit)
attachment.php
   / Need Help lighting for new garage #5
I agree with the 8' High Output lights - that's what I used in my garage. Living in Mo. you'll be getting as cold in winter as I do and you'll appreciate the HO fixtures & bulbs. My attached garage is 16x32 w/10' ceiling and I have 4 of the 8' and they light up the whole place just fine. I have 2 fixtures on 1 switch and the other 2 fixtures each have their own switch - this is what worked well for my setup. Personally, I prefered the lights a little closer to the wall where my workbench & reloading bench are - eliminates your shadow when standing at the bench. The other fixtures are further out from the walls for more even lighting.
   / Need Help lighting for new garage #6
I'm familiar with the 4' fluorescent bulbs/ fixtures & know the 40W "shop blubs" are really cheap. My 24' x 22' garage is lighted with them & I haven't had to change one since '03.
Are the 8 footer bulbs & fixtures comparable in price? (As in not more than double a 4 footer)
   / Need Help lighting for new garage #7
scrivy69, I have a 30 X 40 with a 10'+ ceiling. As far as the the cheapest you could go with the keyhole type sockets and just put in light bulbs. What I did (on the cheap side) and quite pleased is I went to Lowes or HD and bought the 4 foot 2 bulb shop lights with electronic ballast. I think they are T-8 bulbs. I place outlets in the ceiling controlled by wall switches to turn the lights on. I have a total of 4 rows of lights. 3 in the front, due to the garage door opener, 4 in the second row, 4 in the third row, and 3 in the back, due to a small room there. Haven't had any problems with humming due to the cold winters and if one should fail I'll just buy a new shop light. The lights have been in 3 years now and I'm very pleased. I'm sure the 8 foot bulbs as suggested may be better but like I said I went cheap. Let us know.
   / Need Help lighting for new garage #8
Same here: I installed a duplex outlet in the ceiling at every light location, & then just hung & plugged in an el-cheap-o 4' fluorescent shop light at each location. Works great. Very cheap.
   / Need Help lighting for new garage #9
Is this a "garage" or a "shop" garage? I have a 28x32 with 10' ceiling and just used six keyless sockets (about $1 each) with screw-in compact fluorescent bulbs. This is plenty of light for normal work like checking/changing oil, lawnmower blades, etc. I'll use dedicated work lighting if I'm doing close fit-n-finish with a router or something small on the drill press. And no matter how well you light the ceiling, you still can't see the underside of the truck to work there :)
-rus-
   / Need Help lighting for new garage #10
8' HO's are a bit more expensive than the cheap 4 foot fixtures, however, lamps last much longer, light output from a pair of 8' lamps is more than double that of 4-4' lamps. Ballasts are longer lived. When maintence/replacement is calculated out over a period of years cost is the same or slightly less.
   / Need Help lighting for new garage #11
-rus-
Ditto. I did similar. Surface mount boxes and plastic bulb sockets. 75W equivalent CF bulbs. I didn't worry about making a symmetric grid layout. Put one right over the work bench and one in a corner where my tool cabinets are.
Careful you don't have shelving shading your workbench from the light above.
Dave.
   / Need Help lighting for new garage #12
the 4 footers are a lot cheaper, easier to replace, easier to find, and easier to transport.
(T8 not T12)
Yeah, 8 foot is better if you have a warehouse to light, for a garage the arguments fall apart.
Hey everybody thanks so much for all the suggestions I was checking online and found this
Commercial Electric 4 Ft. Shop Light with Lamp Grid and Pull Chain Switch
$22.68/EA
at Home Depot pretty good rating what do you all think?
   / Need Help lighting for new garage #14
$22.68/EA
I think you can get a simpler one for about 1/2 that price. I seem to remember about 11-12 bucks or so last time I looked, not too long ago.
   / Need Help lighting for new garage #15
Everyone I know that started off with 8' fixtures have gone to 4' because of the cost of the bulbs...
where did you see these for $11-$12? electronic or metallic ballast?
   / Need Help lighting for new garage #17
This is what I suspected. While I know HD/ Lowe's carries the 8' bulbs, I can't recall the last time I actually saw an 8' fixture. Whereas the 4' fixtures are everywhere.
   / Need Help lighting for new garage #18
H.D. ... I'll have to check. I've ever been concerned with ballast type, but haven't had any problems so far (7 years) with whichever I got.
   / Need Help lighting for new garage #19
As mentioned put your lights on 2 switches. In my garage I used 2 tube 4' fixtures with electronic ballasts and T8 tubes. Make sure the box says for cold start operation. Some say for use in 60 degree or higher temps. I bought mine at Walmart since they were cheaper at the time than Home Depot or Lowes.
   / Need Help lighting for new garage #20
I recently finished my new home. I have two garage stalls (separate areas): one big two-car stall (29' x 30') and one single-car stall (26' x 12').
I bought the 8' HO fixtures and bulbs at Home Depot. They were a little more expensive, but they are NICE! I can't confirm their lifespan because I have only had them operational for 1 1/2 years, but I can ensure you that when you fip the switch, they turn on NOW! They are BRIGHT too, which is the way I like my shop/garage.
In the big stall, I have six 8' double fixtures and in the smaller stall I have two 8' double fixtures. All eight fixtures are on one 20 amp circuit, but the stalls are independently switched.
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2016 JOHN DEERE 35G EXCAVATOR (A60429)
2016 JOHN DEERE...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
