1990 Ford 4610 SU
   / 1990 Ford 4610 SU #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Anyone have an idea of what one of these is worth? Tractor has about 950 original hours and looks great. Drives like a new one and front end is very tight. All original and no aftermarket parts.
Thanks,
   / 1990 Ford 4610 SU
also has original paint job that still looks very good. Not perfect but very good as tractor has been garage kept.
   / 1990 Ford 4610 SU #3
I think 1989 was the last year for that model .
   / 1990 Ford 4610 SU
Well i thought the same and your partially correct. I've now found 2 1990 tractors that are in fact SU's but heres thing. They were actually made in England through at least 1990 as the serial numbers start with BC. Very interesting. I would like to know too how long they were produced in England. Wish i knew more on pricing as well.
   / 1990 Ford 4610 SU #5
they run from 4000 to 8000 with the one you discrided at the higher end of those figures
   / 1990 Ford 4610 SU
so 1990 was the last year in England too correct? Are there any 1990 american SU's or was 89 the last year for those?
   / 1990 Ford 4610 SU #7
Thanks,
Are you sure it's not a 4630? The SU was a short version of the 4610(4630?) utility tractor and had a different front axle as I recall. I'm not sure that it has remotes. Someone like RickB could tell you more about it than I, but I have heard it's not considered as good as the regular utility version and I think it's because of the front axle configuration. Take that with a grain of salt and holler for RickB because he knows a lot about these Fords. If you aren't going to put a loader on it or work really hard it may be right for you.
   / 1990 Ford 4610 SU
Yeah i'm sure of what it is as i'm a Ford nut and especially an SU nut. I have a couple myself but didn't realize they were made in England as well. Here's a picture of one of the BC serial numbered tractors i found. Check it the rops as this is the style they used when converting to the 3930. I checked in both placed for each tractor and there are serial numbers on sticker under hood and on chassis that match.
As for the strength of the front end they are definitely weaker and lighter, however for bush hogging and general soil disking this tractor is awesome especially in tight places due to very tight turning radius. Just not going to handle a front end loader very long if worked hard.
   / 1990 Ford 4610 SU #9
That's a sharp looking tractor , I have a 1990 ( 4630 ) made in england with the same fenders .
   / 1990 Ford 4610 SU #10
Ford tractors were assembled in Basildon England both before and after the Romeo Michigan plant was closed following the 1988 production. The vast majority of Ford Farm tractors built between 1989 and 2000 and sold in North America were built in Basildon. Noteworthy exceptions include large Fargo-built 4WDs, Versatiles and Genesis tractors built in Winnipeg, Asian compacts, and Mexican tractors. Some tractors built between 1965 and 1989 were also built in Basildon and equipped for sale in North America. There's nothing special or particularly noteworthy about having a post 1964-British built Ford. If you have a post-1988 3 or 4 cylinder Ford utility tractor with blue paint, it is most likely a British built tractor.
2015 Isuzu NPR-HD Flatbed Truck (A51691)
2015 Isuzu NPR-HD...
2016 Isuzu NPR Landscape Dump Truck (A51691)
2016 Isuzu NPR...
378812 (A51573)
378812 (A51573)
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
