ford 7810
   / ford 7810 #1
ford7810
ford 7810+mx120 case
hi all, new member here.
i have a ford 7810 and was thinking of fitting a turbo,
whats your views on doing this? my tractor has 9000 hours but running well!
   / ford 7810 #2
I'm not a mechanic or engineer. But, it raises some questions in my mind. What is your purpose? Why do you want to turbo a 20 year old tractor with 9000 hrs on it? How much will it cost? What parts will it involve other than the turbo? (different air intake, intake manifold, engine head, exhaust system, bigger fuel injectors, etc) What will you gain?
   / ford 7810
ive just realised this is mostly american site?? im over in ireland! are there many 7810s your end?
there is a kit to turbo them available over here, gives them a few extra horses just!
will i put a pic up of the tractor?:thumbsup:
   / ford 7810 #4
While it is true that this site is mostly populated by Americans, the real challenge you have it it is more a compact tractor related site than full-size farm tractor-related. Most members wouldn't know a Ford 7810 if it ran over the top of their compact tractor.
The major downside of turbocharging a 7810 is the lack of piston cooling oil jets in the block, and the fact that a 7810 from the clutch back was designed for the HP of a turboed 4 cylinder rather than a turboed 6. Even an 8210 has only a handful more HP than your stock 7810. There is probably more info about what you want to do on your side of the pond than over here, as turning up the wick on smaller framed tractors is a more popular exercise there than here. We tend to buy and use larger frame tractors.
   / ford 7810
ah, ok. i stumbled on the site when searching so randomly sighned up!
yes i see your point in buying larger tractor, but i need the smaller ford for a particular job but just needs a bit more power.
nice taking to you's anyway.:)
   / ford 7810 #6
I wasn't suggesting that you need to buy a larger tractor, only that it is the more common response over here. I understand that boosting the HP levels on mid-frame sized tractors is far more common on your side of the pond than ours.
Have you been to the Profi site?
profi.com - International Tractors, Farm Equipment & Tractor Machinery Magazine (News, Tests, Videos, Manufacturers)
   / ford 7810 #7
If that's an economical option, go for it, I guess. Just be aware of what Rick mentioned. The clutch, transmission, and rear-end of your tractor was not designed for more hp than you already have. If you get 10% more hp, but it's at the cost of a clutch . . . You get the picture.
We don't see many 7810's over here. But we do have a bunch of 7610's, 6610's, 5610's, etc.
BTW, I've had a New Holland 7610S MFWD for the last 8 years. It's a "bull" of a tractor. Very powerful. 100 hp. It came turbocharged from the factory. Just sold it last week. Replaced it with a cab tractor. I'm really going to miss it. Just couldn't justify keeping it, along with three other tractors.
We're still waiting for the pic. :thumbsup:
   / ford 7810 #8
get a turbo off a 7610s 7910 are a tw series tractor and put it on it. u shouldn't have no trouble with the motor if you do this i have a budy that is from holand that imports fords to the U.S. and he has had some 5000 fords with after market turbos and i have used them to bale hay with no trouble out of them
   / ford 7810
heres a pic lads,
   / ford 7810 #10
Very Nice, I put a 7810 engine in my 6600 recently-goes very well! As rick says the lack of piston oil jets is about the only difference which may cause problems-Im guessing your exhaust manifold is like mine and has the square flange(turbo type manifold?) this makes it easy as they have also the oil gallery for the turbo and the return into the block also. Provided you didnt crank the pump up too much and didnt work the snot out of it I say go for it,find a turbo off a TW25 or the like
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
greenworks (A53421)
greenworks (A53421)
12ft Mobile Creep Feeder (A53117)
12ft Mobile Creep...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
