Do John Deere QA attachments fit others?
   / Do John Deere QA attachments fit others? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
I heard that John Deere QA front end loader attachments were "proprietary". I don't think this is true, but I thought I'd ask before I go look at a used JD bucket. Is this true or will they fit other brands of loaders?
In other words, will a set of JD pallet forks fit my Kubota QA equipped front end loader?
Thanks. :thumbsup:
   / Do John Deere QA attachments fit others? #2
JD does have a very light weight proprietary setup, we call it JDQA vs. the more standardized SSQA. Ask the seller to send you pictures of the rear of the bucket to be sure, and you can search the term "jdqa" for lots more reading.
Seller says he doesn't know, but they were used on a Deere skid steer. He said they load pallets of pavers with them. Thinks they were bought new in ~2005.
   / Do John Deere QA attachments fit others? #4
If they where used on a JD SSL, then you will have no problem-they all use the standard bobtach type setup (SSQA). In your first post you mentioned a front end loader so I assumed a tractor-that could go either way.
OK, Thanks. One more thing: Does the light duty version look substantially different than the standard SS version? I have a good mental picture of what the typical skid steer version looks like. If the light duty is substantially different, I'll know soon as I go see it.
   / Do John Deere QA attachments fit others? #6
Don't mean to butt into your conversation: but yes the JD quick attach system looks very different from the skid steer system. You won't have any trouble telling them apart visually.
Ah, by all means...butt-in anytime! That's very helpfull! :thumbsup:
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2004 Hyundai Santa Fe SUV (A48082)
2004 Hyundai Santa...
Platform/Catwalk (A50860)
Platform/Catwalk...
2016 Ford F-550 4x4 12FT. Landscape Dump Truck (A48081)
2016 Ford F-550...
2023 Ford Explorer SUV (A48082)
2023 Ford Explorer...
