Do John Deere QA attachments fit others?
   / Do John Deere QA attachments fit others? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
I heard that John Deere QA front end loader attachments were "proprietary". I don't think this is true, but I thought I'd ask before I go look at a used JD bucket. Is this true or will they fit other brands of loaders?
In other words, will a set of JD pallet forks fit my Kubota QA equipped front end loader?
Thanks. :thumbsup:
   / Do John Deere QA attachments fit others? #2
JD does have a very light weight proprietary setup, we call it JDQA vs. the more standardized SSQA. Ask the seller to send you pictures of the rear of the bucket to be sure, and you can search the term "jdqa" for lots more reading.
Seller says he doesn't know, but they were used on a Deere skid steer. He said they load pallets of pavers with them. Thinks they were bought new in ~2005.
   / Do John Deere QA attachments fit others? #4
If they where used on a JD SSL, then you will have no problem-they all use the standard bobtach type setup (SSQA). In your first post you mentioned a front end loader so I assumed a tractor-that could go either way.
OK, Thanks. One more thing: Does the light duty version look substantially different than the standard SS version? I have a good mental picture of what the typical skid steer version looks like. If the light duty is substantially different, I'll know soon as I go see it.
   / Do John Deere QA attachments fit others? #6
Don't mean to butt into your conversation: but yes the JD quick attach system looks very different from the skid steer system. You won't have any trouble telling them apart visually.
Ah, by all means...butt-in anytime! That's very helpfull! :thumbsup:
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
2016 Ford F-250 Knapheide Service Truck (A48081)
2016 Ford F-250...
Ferris IS2100Z Zero Turn Mower (A50860)
Ferris IS2100Z...
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A48081)
2015 Ram 1500 4x4...
2022 Ram 1500 Crew Cab Pickup Truck (A48081)
2022 Ram 1500 Crew...
