oil for GR 2100
   / oil for GR 2100 #1
csr0831
Hey Guys....
Anyone know if its ok to use API - SL clasification in this diesel? Got plenty of it, but none of the "C" clasification oils. Thanks : )
Chris
   / oil for GR 2100 #2
You need to put diesel oil in it. Save the gasoline oil for your car/other equipment.
   / oil for GR 2100 #3
GR2100 is the gasoline engine, right? I believe G2110 is the diesel. Where are you located at? Hot climate, cold climate, or a mix of both? All of my equipment, gasoline or diesel, small or large enigne, offroad or onroad, gets Mobil 1 5w-40. This one oil covers all my applications. Philip.
   / oil for GR 2100
Yeah, thats what I did, but it seems to me that I read somewhere that oils classified SL-SM also met the requirments for the same viscosity in the "C" oils. However, better safe then sorry...I went for the diesel oil.
   / oil for GR 2100
The GR 2100 is the diesel...predecessor to the 2110.
   / oil for GR 2100 #6
Most oils you find on the shelf at WM or local auto parts store are for gasoline vehicles, with an API S_ rating. The HDEO, usually in a different section, is rated C_. Most of the HDEO are dual rated for mixed fleets, usually carrying an older S_ rating as well. HDEO are typically found in 5w-40 and 15w-40 weights, but with searching at special stores (TSC, Rural King, Kubota dealer, JD dealer), you can also find 0w-40, 10w-30, 30, and 40 weights in HDEO. Philip.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
1998 John Deere 544H Articulated Wheel Loader (A50322)
1998 John Deere...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A52128)
John Deere 946...
1275 (A50490)
1275 (A50490)
