PTO Driven Digger???
   / PTO Driven Digger??? #1
dieselscout80
South Carolina
New Holland TC45DA
Could a mounting a small transmission between the tractor PTO and the diggers PTO shaft work to slow down the auger and to provide for reversing the auger.
   / PTO Driven Digger??? #2
Assume talking a post hole auger?
If there is room, might work fine. Do you have a tranny in mind?
   / PTO Driven Digger??? #3
Reucing the PTO output speed through a gearbox will multiply the output torque. You need to determine if the implement can handle the increased torque and if the implement will be safe. By safe I mean will the tractor turn the digger or will the digger turn the tractor.
Reversing the auger will depend on the transmission you select. I assume you want to be able to switch between forward and reverse by selecting a gear on the transmission? Should be doable if the tranny has a reverse gear to select.
-Jim
   / PTO Driven Digger??? #4
You'll also want to ensure the transmission can handle the torque. At 540 rpm, there is a smidge under 10ft/lbs per hp at the PTO shaft. So you're well into automotive torque categories, 25 PTO hp would be ~245ft/lbs or so. Also, with the lower speeds, there won't be as much viscous oil distribution through the system. But if you can get a dirt cheap tranny, it might be worth a shot. Certainly would be an interesting project anyway!
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
Quick Attach EZ Axe Skid Steer Tree Shear (A51039)
Quick Attach EZ...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
2012 FORD F250 (INOPERABLE) (A50854)
2012 FORD F250...
2022 Caterpillar 420 Extendahoe Loader Backhoe (A49461)
2022 Caterpillar...
