PTO Driven Digger???
/ PTO Driven Digger??? #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
Could a mounting a small transmission between the tractor PTO and the diggers PTO shaft work to slow down the auger and to provide for reversing the auger.
/ PTO Driven Digger??? #2
Assume talking a post hole auger?
If there is room, might work fine. Do you have a tranny in mind?
/ PTO Driven Digger??? #3
Reucing the PTO output speed through a gearbox will multiply the output torque. You need to determine if the implement can handle the increased torque and if the implement will be safe. By safe I mean will the tractor turn the digger or will the digger turn the tractor.
Reversing the auger will depend on the transmission you select. I assume you want to be able to switch between forward and reverse by selecting a gear on the transmission? Should be doable if the tranny has a reverse gear to select.
-Jim
/ PTO Driven Digger??? #4
You'll also want to ensure the transmission can handle the torque. At 540 rpm, there is a smidge under 10ft/lbs per hp at the PTO shaft. So you're well into automotive torque categories, 25 PTO hp would be ~245ft/lbs or so. Also, with the lower speeds, there won't be as much viscous oil distribution through the system. But if you can get a dirt cheap tranny, it might be worth a shot. Certainly would be an interesting project anyway!
(2)16.9-24 TIRES W/ 8 LUG RIMS (A64280)
(2)16.9-24 TIRES...
Agri GPS Module (A63117)
Agri GPS Module...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2019 Chevrolet Malibu Sedan (A61574)
2019 Chevrolet...
