Dolly for my rotary cutter
   / Dolly for my rotary cutter
Amen to that--I turned 61 in July, so any way I can make life easier is welcome!
   / Dolly for my rotary cutter #12
I don't need the dollies for attaching, just for moving things around in the barn to better arrange things. I was looking at swivel casters today at TSC, $10 each for 3". Right above them is a moving dolly with 4 swivel casters for $20, so I bought two of the dollies and got the casters and bolts for $5 each.
   / Dolly for my rotary cutter #13
I did exactly the same thing, even at TSC :thumbsup:
   / Dolly for my rotary cutter #14
Snowmobile Dollies (small with 4 wheels) work great. I put one on each side, and the wheel takes care of itself. I can move it around with 1 hand easily, and the best part is they don't take up any space and can be used for everything else.
They are like 8 inch square pieces of steel with 4 wheels under them. You can buy them in sets of 3 for like $30. I have about 6 sets and use them for everything in the garage.
   / Dolly for my rotary cutter #15
Can someone tell me the trick to getting the top link connected to the i-match? I got it adjusted out but I can connect the bottom but can't get the top. Also, do I really need to block up my rotary cutter since I have an imatch?
   / Dolly for my rotary cutter #16
Has anyone made a dolly for a subframe mounted backhoe? I've been thinking of making one based on a pallet and then get a pallet jack to raise and lower the backhoe onto the mounting hooks.
   / Dolly for my rotary cutter #17
I decided to build a dolly for my rotary cutter in order to make it easier to hook up to my Kubota. I made it using 4X4's, 2X4's, and 4 fully rotating casters. What a difference in hookup! It took me less than 10 minutes to get the cutter hooked up including the driveshaft. With the fully rotating casters, I could easily move it to make minor adjustments in hookup. Removing the cutter was easy too, just slide the dolly underneath and unhook; then stow the cutter out of the way. Pics below give an idea of what it looks like, and can be built to suit various sizes of attachments. Mike
Nice setup, Mike. I may do just the same, as I have 6 heavy duty casters laying around taking up space anyway.
For now, I've been using a couple of $7.99 (on sale) Harbor Freight dollies to move my 4' JD rotary cutter around the barn.
   / Dolly for my rotary cutter #18
Are you referring to a backhoe with the subframe as part of the BH or the SF as part of the tractor? If you mean the latter, yes I have a Woods BH90-X chained down on a dolly. I use the hydraulic stabilizers ILO a pallet jack to raise/lower the BH for the off/on proceedure. Glad to offer my lumber and plywood build experience, back in my few threads there are two about the build. Not sure if this thread is the place to discuss this, you might want to start a new one or just PM me as needed. Even on a dolly they are sluggish but doable to move around-much easier than no dolly.:)
   / Dolly for my rotary cutter #19
Used INDUSTRIAL CASTERS 4"-5"-6"-8" show up on eBay incredibly cheap from time to time. Type in a search for INDUSTRIAL CASTERS or HEAVY DUTY CASTERS and see what comes up. In April I purchased four, used, 4" industrial casters for $30 delivered. While not specified I would guess-timate capacity is 1,000 pounds each. Mine came from liquidation of a mill in South Carolina.
   / Dolly for my rotary cutter #20
I know this is an old post, but it helped inspire me to build a dolly for my cutter. Had some 3/16" square stock, 1/4" plate, and some casters from another project laying around so I put this thing together, works slick!! No more getting out the tractor to move the cutter around. Thanks for the Post Mike!!
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
