What equipment to mow a slope with?
   / What equipment to mow a slope with? #11
A third NO on the DR. I have one and trying to mow the slope on the pond side, its gotten wet a couple of times! I think it would not tend to do so if it was a two-wheel drive, it just wants to go downhill, especially if the ground is a little wet. It'll wear you out trying to keep it straight too. A sickle bar mower with a hydraulic lift is what I want, but not been able to afford one yet.
   / What equipment to mow a slope with? #12
I own a Steiner 430 with dual wheels with a 60" mower deck (it came with the house), that is a goat. It is too slow for flat areas so I'm looking for a ZTR with a 72" deck for the flatter areas.
   / What equipment to mow a slope with? #13
Here is the mower with the 9 ft reach and handy for many other mowing projects as well. International #1300 with 9 ft cutter bar. Standard catagory 1 three point hitch. Priced at $1750 + modest shipping. Ken Sweet
   / What equipment to mow a slope with? #14
Is there a sickle mower that simply rides the terrain and doesn't need a rear hydraulic remote?
John
   / What equipment to mow a slope with? #15
John
Both the 3pt mount and the trailer type will ride the terrain, the cylinder only raises the bar to clear obstacles... the tip and heal down pressure is set via a spring load, that lets the bar follow the ground. KennyV
   / What equipment to mow a slope with? #16
Thanks. I guess the LTD (local tractor dealer) is conflicted. Now, when Spring returns, I will have something else to consider.
John
   / What equipment to mow a slope with? #17
I use a weed trimmer on the steep inside of my dam. Just have to be careful not to lose balance and fall in the pond.
   / What equipment to mow a slope with? #18
John
We sell about 150 sickle mowers a year that do just that. The only thing a cylinder is good for, is when a operator has health or back problems and can't lift 40 or so pounds to transport position. Ken Sweet
   / What equipment to mow a slope with? #19
Posted wrong, deleted.
   / What equipment to mow a slope with? #20
I use a Zero Turn Tractor (ZTT) to mow my front lawn and mound septic system which are both very steep. So steep when I first started mowing I would only cut up/down, finally got comfortable enough to mow side slope, even though I was hanging on one fender or another. Now I'm pretty used to it and the tractor does great. The extra-wide stance and low CG are perfect for a slope. And, the turning radius is great for getting around all my trees on the septic mounds.
Good luck!
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
