Hyd Cyl for front hitch angle kit??
   / Hyd Cyl for front hitch angle kit?? #1
tcfamy
Superior, WI
Cub Cadet 5234D
Greetings,
Does anyone have the specs on the hydraulic cylinders for the front mount angle kit (590-623-100) for the 5000 / 6000 / 7000 series Cub? Nothing is available thru the dealers and on the usual Ebay, Craigslist. I tried matching up the fixed link to available cylinders from several suppliers, but nothing is intuitively correct. So if you have diameter x stroke, and any other specs - greatly appreciated. I can work on the rest.
Tom
   / Hyd Cyl for front hitch angle kit?? #2
If no one else responds I can get you the measurements in 3 weeks, when I get back home. I've got an angling kit on my 5234. I would think there should be some aftermarket cylinders that would fit?
Thanks Scout. Not a big hurry, but who knows when the first snow will hit here! ---- Tom
   / Hyd Cyl for front hitch angle kit?? #4
Scout, I would appreciate those measurements also.
   / Hyd Cyl for front hitch angle kit?? #5
No problem....I get home on the 8th of October. I will get measurements and pics directly thereafter....
   / Hyd Cyl for front hitch angle kit?? #6
OK....looks like body length is 11".....the piston bore is 3/4".....I will get some more measurements tomorrow.
Thank you Scout!
   / Hyd Cyl for front hitch angle kit?? #8
Yes, thanks. That makes it much easier.
   / Hyd Cyl for front hitch angle kit?? #9
Just double checking, are you sure on the 3/4" bore? That seems kind of small compared to most cylinders I've seen for this use. Maybe because there's 2 of them instead of 1.
   / Hyd Cyl for front hitch angle kit?? #10
Sorry for the delayed response gents, been up to my ___ in projects.
Yes, the bore is 3/4".
The extended length is ~ 21", and the fully closed length is ~ 14".
Hope this helps!
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2016 Ford Expedition SUV (A55853)
2016 Ford...
2020 JOHN DEERE 700K LGP CRAWLER DOZER (A52707)
2020 JOHN DEERE...
NORTHERN AG MIST SPRAYER (A57192)
NORTHERN AG MIST...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
Mini Margaritaville Truck (A55853)
Mini...
