Can my tractor pull this plow?
   / Can my tractor pull this plow? #11
Do you think it would be reasonable to ask my Kubota L2350 (25HP 4WD) to pull this plow or one like it?
John Deere plow
My Dad used to pull a two bottom plow with a IH Super C gas tractor with no trouble. Can I expect similar performance from a CUT of similar HP?
Possibly- if you changed the shares to the Weiss soil deeep conservation plow shares as they have less than a third of the surface area.
You should buy the single moldboard unit from ken that he showed you as you will have less drag and you will not have to replace any moldboards.
Thank you all for your input. It must just have been fate because as soon as I read your comments and checked Craigslist today, this popped up:
One Bottom Plow
I'm picking it up on Friday. I figure even if it's not great it's still probably worth 100 bucks.
   / Can my tractor pull this plow? #13
One Bottom Plow
That is one of these new style plows and they are not worth hauling home. They will not hold up. Ken Sweet
Well, since I've already told the guy I'll take it then I guess I'll get to practice my welding skills. :(
   / Can my tractor pull this plow? #15
John Deere plow
I have that exact plow--paid $150 for it a few years ago. I pull it with my Mahindra 5525 (54 hp engine, 45 hp pto, 2WD).
The 3pt hitch assembly on the plow was shot--wouldn't hold adjustments. So I had to weld up a modified hitch to get the plow to work.
Your 25 hp tractor probably only has about 18-20 hp on the drawbar. Even with 4WD I'd say you're marginal on power.
   / Can my tractor pull this plow? #16
Reason I say is I have a old Ford 2 bottom (about like that one) that came with the 8n's etc and I have no idea how they were expected to pull it must have been perfect dirt is all I can say!
I pull a Ford 3 bottom with an NAA.
It's ALL about soil type and moisture
I was lucky, and did it before I read it wasn't possible ;)
   / Can my tractor pull this plow? #17
That is a nice mod on that hitch. Looks like you got your hitch pins offset about right. Ken Sweet
   / Can my tractor pull this plow? #18
There hasn't been one person say anything was impossible just difficult overall.
You obviously don't have a better solution or you would be using it I know I would.
   / Can my tractor pull this plow? #19
Thanks.
I measured the old hitch assembly and used the two diagonal supports that came with the plow to get it close. I allowed for a little bit of adjustment in the new hitch assy.
2006 Godwin GHP45KW-RC45kW Towable Generator (A56857)
2006 Godwin...
John Deere 5055E (A53317)
John Deere 5055E...
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2007 FRAC TANK 500BBL WHEELED (A58216)
2007 FRAC TANK...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
