10K winch on trailer questions
   / 10K winch on trailer questions #11
Here's what I made for my trailer. The box is attached to a 2" draw bar so I can move the winch to my truck receiver, or just remove it altogether.
Nice job! I was going to suggest a tool box arrangement, but you beat me to it with one on steroids! :D
+1 for battery on trailer (just remember to keep it charged).
   / 10K winch on trailer questions #12
It's guys like you that make the rest of us look mediocre.
Nice build. I especially like the lights. I've been debating about adding work lights to my trailer somehow. I now know how to do it.
   / 10K winch on trailer questions #13
I have a winch on my tilt trailer. The winch draws more amps than the charge lead wire to the plug can handle so I installed a battery in the trailer box to absorb the load. That way the charge lead wire can keep the trailer battery topped off while driving. I also installed a circuit breaker on the feed for the charge lead wire instead of a fuse.
   / 10K winch on trailer questions #14
Is the circuit breaker one of those that will automatically reset after X minutes?
   / 10K winch on trailer questions #15
Yes, the CB resets automatically within a few seconds when its overloaded. I bought it at Advance Auto but I'm sure others must carry them as well. I went with a CB because even with a battery on the trailer using the winch under heavy load would blow the fuse. I figured a CB was safer than buying a box of extra fuses.
10K winch is mounted to 14K GN 20+5 trailer with deep cycle by its side.
Tomorrow is the test trying to load a 1960's era car.
Anybody ever winched a car or truck up onto a deckover trailer??
How well did it work?? I have drove and used chain hoist to get many cars and trucks on a normal car hauler but never up on a deckover...
   / 10K winch on trailer questions #17
Only a few hundred times some didn't even have wheels 8K ramsey to the truck bat. On larger loads I use a doubler block.
   / 10K winch on trailer questions #18
Haven't winched up on a deckover but have winched up dead vehicles on my tilt bed trailer (see avatar). I'm guessing its a 15-20 degree angle.
Car was winched up and down off my GN deckover with no problems at all. Used a Deep Cycle battery to power the winch and it all worked great.
Thanks for the help
   / 10K winch on trailer questions #20
Glad it worked out for you. Nice having the trailer fully self sufficient. I may be **** but I have my winch set up like yours and also a tool box with a extra tail light, bottle jack, 4 way lug wrench, 8 straps, 4 T hooks, 4 Mini J hooks, 4 10' chains and binders, ect. I want to be able to hook up and go in a hurry, not be looking around for all my supplies.
Chris
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2019 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A58018)
2019 VOLVO...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
Kubota L4701 (A53317)
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
