10K winch on trailer questions
   / 10K winch on trailer questions #11
Here's what I made for my trailer. The box is attached to a 2" draw bar so I can move the winch to my truck receiver, or just remove it altogether.
Nice job! I was going to suggest a tool box arrangement, but you beat me to it with one on steroids! :D
+1 for battery on trailer (just remember to keep it charged).
   / 10K winch on trailer questions #12
It's guys like you that make the rest of us look mediocre.
Nice build. I especially like the lights. I've been debating about adding work lights to my trailer somehow. I now know how to do it.
   / 10K winch on trailer questions #13
I have a winch on my tilt trailer. The winch draws more amps than the charge lead wire to the plug can handle so I installed a battery in the trailer box to absorb the load. That way the charge lead wire can keep the trailer battery topped off while driving. I also installed a circuit breaker on the feed for the charge lead wire instead of a fuse.
   / 10K winch on trailer questions #14
Is the circuit breaker one of those that will automatically reset after X minutes?
   / 10K winch on trailer questions #15
Yes, the CB resets automatically within a few seconds when its overloaded. I bought it at Advance Auto but I'm sure others must carry them as well. I went with a CB because even with a battery on the trailer using the winch under heavy load would blow the fuse. I figured a CB was safer than buying a box of extra fuses.
10K winch is mounted to 14K GN 20+5 trailer with deep cycle by its side.
Tomorrow is the test trying to load a 1960's era car.
Anybody ever winched a car or truck up onto a deckover trailer??
How well did it work?? I have drove and used chain hoist to get many cars and trucks on a normal car hauler but never up on a deckover...
   / 10K winch on trailer questions #17
Only a few hundred times some didn't even have wheels 8K ramsey to the truck bat. On larger loads I use a doubler block.
   / 10K winch on trailer questions #18
Haven't winched up on a deckover but have winched up dead vehicles on my tilt bed trailer (see avatar). I'm guessing its a 15-20 degree angle.
Car was winched up and down off my GN deckover with no problems at all. Used a Deep Cycle battery to power the winch and it all worked great.
Thanks for the help
   / 10K winch on trailer questions #20
Glad it worked out for you. Nice having the trailer fully self sufficient. I may be **** but I have my winch set up like yours and also a tool box with a extra tail light, bottle jack, 4 way lug wrench, 8 straps, 4 T hooks, 4 Mini J hooks, 4 10' chains and binders, ect. I want to be able to hook up and go in a hurry, not be looking around for all my supplies.
Chris
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2020 Deere 50G (A53317)
2020 Deere 50G...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
