Buying Advice Opinions on 4wd compact tractor
   / Opinions on 4wd compact tractor #11
RD MacGregor "rocks with an individual volume of about 4.5 cubic feet. Granite is 2691 #/cuft,"
I figured the volume assuming it is roughly a sphere (he supplied dia).
V=4/3 Pi (r cubed) I got 14 ft cubed
Ditto. But granite is NOT 2691#/cu ft. In any case, that is too big to lift with an FEL. Use a backhoe or excavator.
JayC
   / Opinions on 4wd compact tractor #12
If I did my calculations correctly, you are looking at moving rocks with an individual volume of about 4.5 cubic feet. Granite is 2691 #/cuft, so these boulders would be about six tons each (sandstone would be about 5 tons and even pumice would be nearly a ton and a half)! You might be able to drag them, but I don't know of any CUTs that will pick them up, even with the 3ph (unless you have a field of pumice boulders). If you have very rough (or soft!) ground, dragging could be a challenge, too.
Even if you could pick up a rock that heavy, carrying it up and down hills could be a serious risk with a conventional tractor.
BOB
Mass, Weight, Density or Specific Gravity of Bulk Materials
Went to that page and saw that it was 2691 kilograms per cubic meter. Found a converter and ran the number and it gave 168 lbs/cuft. Don't know if that's right or not, but it seems more reasonable.
Mass per Volume - Density Calculator
   / Opinions on 4wd compact tractor #13
I found it to be 168 p/cf also. But I also came up with 14 cf for a 3' sphere... which is like 2400lbs.
   / Opinions on 4wd compact tractor #14
I could lift that and still drink a beer.
JayC
   / Opinions on 4wd compact tractor #15
JayC
Yeah, I could too. But the size tractor wasn't really discussed -- I think the OP mentioned 22-50 HP range.
Not to mention, 2400 lbs of dirt in a bucket is one thing. A 2400 lb rock dangling from a chain on a FEL navigating sloped terrain is entirely different.
I found that I have a New Holland dealer near me. Does anyone have experience with the Boomer 8N? I love the retro styling.
   / Opinions on 4wd compact tractor #17
For the few big granite boulders that I have had to move that were too big to pick up I just rolled them with the front forks instead of the bucket, more control, visibility, and leverage. Just go slow and don't let it get away from you on the hill.
Most of the rock moving will be on level ground. The tractor will also be used to remove snow on a 1/2 mile drive, and run a pto bush hog mower.
   / Opinions on 4wd compact tractor #19
The new 8n looks great. But for way less money you can get a 3050 and still have all the features. Same HP too.
   / Opinions on 4wd compact tractor #20
I work in granite. 180 lbs. c/f. At any rate, you're talking about some heavy awkward objects that can shift unpredictably. Be very careful with FEL
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
CAT 941 Crawler Loader (A47477)
CAT 941 Crawler...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
DUMP HOPPER (A53843)
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
