JDTank
- Joined
- Oct 5, 2010
- Messages
- 693
Good day all!
I am new here and I am in the market for my first tractor. I have been lurking in the forums for the last few weeks trying to learn as much as possible, and so far I have gained a great bit of knowledge thanks to you folks here.
Well, first off I guess I should start by listing my needs.
- Once a year spreading about 3 or 4 truck loads of pole shavings in the 4 horse paddocks we have on our property.
- rough cut 5 acres of high grass, roughly 2 feet in length. Not especially hard grass, just picture normal lawn grass 2 feet high.
- Pull an attachment to turn the surface of a 1 acre grass field for horses.
- Level the turned surface, re-seed grass.
- Level a riding arena, 300 ft by 100 ft.
- Dig out tree stumps, flatten ground covered in weed trees, push over trees.
- Finish mow between 2 - 3 acres of grass on the home property, this cannot be torn up like the ditch grass can.
I was HOPING to find one tractor to do EVERYTHING with, instead of buying a riding mower, AND a loader tractor. However, the more research I do this seems it may have to be the case. I would love to have a backhoe, but they are SERIOUS extra dollars around here, add on a backhoe is adding $11,000 to the price tag.
Are mid mount mowers, say the 7 Iron series, capable of cutting 2 ft high ditch grass? I was hoping to avoid having to purchase a rear PTO driven cutter, as it is overkill for the situation I am in.
The current tractors I am looking at are:
-John Deere 3320, 300CX loader, mid PTO, 3rd valve, for $23,500, including tire ballasting.
-John Deere 4105, 300CX loader, 73'' bucket, basic model of the 4000 series, price of $24,500, tires ballasting included.
-John Deere 4520, 400CX loader, all the bells and whistles, for $38,500.
These prices ARE in Canadian dollars as I am from British Columbia.
Now, I have looked through Kubotas website, and it would seem to me you can get a substantially larger tractor from them, for the same money you would pay for a much smaller John Deere. I have not gone to look at any of them, or drive them, let alone research them much. I have always been a diehard green fan!
I used a older 30HP 790 for the last 4 days to move pole shavings and I have to say I was unimpressed. The only tractors I have driven were of the 100HP and up range, so I am very used to powering through any hill of any material and taking half of it in one bucket scoop. This thing took forever to move any large amounts of material. It was also a standard gearbox, so all the loader work the last 4 days has been drive in, shift, back out, shift, drive to dump area, dump, shift, back up, shift. I can't take that anymore!
Any help would be appreciated. Thanks in advance folks!
