Northern Tool Chain versus Oregon Chain Saw Sharpener
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #21
I've also have seen sparks coming out when cutting wood. That makes sense, a little bit of something stuck in the wood. I am also lucky to get two tanks of fuel through mine before it needs sharpening.
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #22
As mentioned, there is an attachment for the Dremel tool that is easy to use, you don't have to take the chain off the saw, it takes two minutes to sharpen the chain. I heat my house exclusively with wood and I've been using this setup for the last ten years, it only costs a few bucks. Can't see spending anything more than that. If I'm out in the woods, the hand file works almost as fast. Nothin' easier than sharpening a chain. It takes more work to sharpen my pocket knife....almost.
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #23
I have the Northern Tool sharpener. I absolutely love it. Sometimes I have to sharpen five chains a week with it. It takes about 30-45 minutes for all of them and they cut like a hot knife through butter after I'm done. Well worth the money IMO. :)7
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #24
I got the HF saw sharpener, played with it for 30 minutes, and put it back in the box. I use a dremel tool and the appropriate sized stone attachment. Taking the chain on and off the saw is too time consuming for me.
Mike
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #25
I touch mine up by hand during the day and then use a bolt on guide from time to time to true everything up.
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #26
I don't necessarily like removing the chain from the bar but it forces me to do a through cleaning of the grooves, oilways etc. and a through inspection of the whole assy. including the chain brake and housing/fins. I use compressed air and goggles and blow out every nook and cranny. Tons of stuff accumulates in these areas in no time.
At the same time I flip the bar over to increase its life and swap out to a sharp chain. This is what the saw mfg's. recommend and it works well for me.
I mostly hand file or drop off spare dull chains - my time is more valuable doing other things than sharpening chain on a regular basis.
As to dirt and sparks etc. Loggers toss the first ten feet of trees often to eliminate the possibility of nails, barbed wire etc. having grown into the tree. To eliminate or at least reduce the effects of dirt and rocks when cutting logs consider a peavy, or lifting the log at one end and cutting to lengths half way through from the top and then rolling the log to cut the rest of the cut. Or land each log across two other logs that are already on the ground at your log landing, to raise your log to be cut off the ground.
If you have a tractor winch one can lift the log to the backplate to keep it off the ground and then discard the other end that drags in the dirt.
I like Stihl and Oregon chains and use my beat up older bars and chain for cutting where I know I'm likely to hit dirt or rocks; like around stumps and roots, etc.
On my flip house property I just sharpened a chain and immediately saw sparks as the chain found its way to hidden barbed wire in the area around the tree stump!:(
My friend who is a pro, like I used to be long ago, says whenever you need to find metal sharpen your chain!:confused2:
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #27
I run 4 saws and have 4 to 6 spare chains for each saw. I take a minimum of two saws in the woods with me, as well if I am bucking up lengths, (which I skid to my cutting yard with a Farmi 601). I always take a spare chain for each saw with me.
I have put up 70 cord in the last 3 years, as I heat my farm house with wood via a wood boiler (Central Boiler).
Thus, fwiw, are my credentials.
So, my opinion about a sharpener:
I bought the NT chain sharpener 3 years ago (it was priced $139 then) and on a cost benefit basis, it is the best tool I have ever purchased. As experienced sawyers know, tooth consistency is very important to maintaining a clean, straight cutting saw. The beauty of having this sharpener is, you pick the tooth with the most damage and set the sharpener to make that tooth "right". Then you cut all the other teeth the same. Viola, you have what cuts like a "new" chain.
I do "dress" my chains while sawing during the day. I mounted a vice on the back side of the FEL bucket just for that purpose. However, after nearly a dozen years of running chainsaws I can say that even the most attentive hand sharpener cannot get a chain "right", especially a well used chain. any professional logger will likely tell you that, also.
I find I end up sharpening my complete set of chains (about two dozen chains in total) at least twice a year, so that says that even with hand "dressing", I am going through nearly 50 chains a year. At that rate the sharpener paid for itself the FIRST time I sharpened my set of chains, and has since saved me an additional $600 bucks.
PLUS...... Nothing is more satisfying then when a saw pulls itself through a 2 foot diameter hard wood log. NOTHING.
Get the sharpener that lets you set all three angles, fix the tooth cut once per chain and has a tooth vice that insures every tooth is addressed exactly the same. You will be very pleased with the results.
Oh yeah, and don't forget to cut your rakers.........
'Cept for sharpening my own chains, I agree with what Coyote says. I can sharpen a set (24) of my chains in under an hour.
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #28
My $5 sharpening is $10 this year.
   / Northern Tool Chain versus Oregon Chain Saw Sharpener #30
You guys must be cutting cleaner logs than those I drag out. I feel I'm doing good if the blade is still SHARP after two or three tanks of gas. I carry a file on the tractor. At night the saw goes into the vise for a more precise sharpening...
I have two of those fancy $35 rigs and a 12V Dremel type hanging on the wall. Been trying to give them away for a few years now....
A file in an Oregon file holder does it for me. (about 4-5 bush cords /year)
I agree, it depends on the job I'm doing but normally after 3 or 4 tanks of gas I touch up the blade. A SHARP blade saves time and wear & tear on the saw and operator. If the saw is not ejecting large chips its NOT sharp. After using many different sharper over the years I have found that the battery powered Dremel tool with the chainsaw attachment the most useful. The Dremel is set to low speed. It's portable, small, and a great time saver. When in the shop I will use a sharper like Northern Tools. If I could only have one power sharping tool it would be the Dremel tool.
Shop Dremel MultiPro Kit at Lowes.com
Shop Dremel 6-Piece Sharpening Attachment Kit at Lowes.com
2014 Ford Escape (A50323)
2014 Ford Escape...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2001 Freightliner E-One Pumper (A52377)
2001 Freightliner...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
