Small roller repair
   / Small roller repair #1
4shorts
Elite Member
Bay Roberts, Newfoundland
Kubota 5740,BX25D
Today we had a customer come in the shop dragging a 6 foot roller asking if I could repair it and right away. Seeing he is one of our best customers I said sure and dropped what I was doing and started in at it.
The end piece was completely off and it looked as if something jammed it up because it was blue with heat. The bearing didn't seize so it must have been something else that I wasn't sure of.
Problem number one was, My lathe was to short to swing this thing so I used a die grinder with a carbide rasp and removed the old welding on the side of the roller.
Problem number two was. How am I going to get the new shaft welded straight coming out from that pipe without a lathe? Well I got a brain fart and came up with what you see below.
I made the new shaft on the lathe. Then I machined two large washers. The inside one was 1/4" thick and the outside one was 1/2 " thick. Once I had all the machining done I put the machined items in the welding postioner and used the Millermatic 350P:cool2: on pulse for most of the welding.
I then took the part and fit it tightly into the pipe and welded it again. It took all morning to do it but the customer was sure pleased when he came back to pick it up.
I know. It's boring but I just wanted to post something :eek::laughing:
   / Small roller repair #4
Seems a shame hide two of those beautiful welds inside the roller!
Thanks Farmer. It's funny you said that because someone else said that in the shop today. Hum. Might be something to it :). Thanks again for your post.
   / Small roller repair #6
I know this is extremely rude to ask so ignore it if it exceeds common decency.
How much does a repair job like this cost the customer?
I only ask because your work is so admirable and professional that it is of considerable interest to know what skills at your level receive for compensation.
   / Small roller repair #7
excelent work..
soundguy
   / Small roller repair #9
4shorts,
A Great Post is Never Boring!!!!.....Nice Work......Thanx for pics too....:thumbsup:
   / Small roller repair #10
I don't weld well enough to ever show it on TBN but if photo #5 is normal for you; YOUR THE MAN!
MarkV
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
7096 (A51573)
7096 (A51573)
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
