My Jinma 254 has trouble starting in the cold?!?!?
   / My Jinma 254 has trouble starting in the cold?!?!? #1
Part timer
Member
Kentucky
2008 jinma tractor king 254
Hi I have a Jinma Tractor King 254 and the last couple days I have fired it up in the morning and it struggles to start. I recieved no paperwork with it and I'm curious is there a special way to preheat the glowplugs before cranking?
Actually it was 48* F outside yesterday and I had to use the compression release to get it to start!
I do have a block heater I am going to install on it but 48* isn't even cold yet..
Anyone have any thoughts or info?
   / My Jinma 254 has trouble starting in the cold?!?!? #2
Glow plugs might need to be cycled twice,hold them on for 15-20 sec,,than if it don't start right up on about first crank,,start from scratch,again...main thing is not to just keep cranking.
Thanks I'll try that on the next cool morning I usually leave the key in the ON position for 5 secs or so and it would fire right up until it started cooling off outside also my kids ran the battery down on it a few days ago so I had to charge it. That migh have been a factor also... Thanks
   / My Jinma 254 has trouble starting in the cold?!?!? #4
If your tractor is equipped with an ammeter you will see a high current draw, about 30 amps that tapers off as the plugs heat. When the plugs are as hot as they are going to get the current reading will level off at about 5 amps per plug.
I start my engine in this order;
Compression release, set.
Spin the engine till there is oil pressure.
Heat the glow plugs. 20-30 sec. more if colder.
Spin the engine again with the compression release set and than drop the release.
Sometimes you may have to hold the key in the heat position until the engine smoothes out.
   / My Jinma 254 has trouble starting in the cold?!?!? #5
The glow plugs do not come on when the key is only in the on position. To make the glow plugs heat up you have to hold the key in between the on position and the start position. You will know you have in the right position when the amp gauge shows to be discharging. If you hold the key in between the on position and the start position and the amp gauge does not show to be discharging, check your fuse box to see if the fuse for the glow plugs is still good.
   / My Jinma 254 has trouble starting in the cold?!?!? #6
Halfway between on and start is the pre-heat position. Your key placard should be labeled from left to right as follows: ST(for start), OFF, ON, H(for heat), and ST again. As mentioned, when you get to the H position, you should see at least 30A of current draw on the Ammeter. This will taper off to about 20A after about 20 seconds. I believe on this ignition switch, it maintains the heat contacts while you rotate the key to start, so it is still heating while you are cranking the engine. Mine starts reliably down into the low 40's-upper 30's. Towards freezing it may take a second attempt. Still running the original battery since 2005, but I do keep my electrical contacts clean and weatherproofed. This is important as that starter needs a good supply to spin up properly. A quick check for this is to measure the voltage drop when cranking. Measure first at the battery terminals, then measure the voltage drop at the starter. In a perfect world, these would be the same. If the starter voltage drop is significantly lower, then you are loosing the difference in the wiring and connections.
I installed a 1000W tank type heater in line between the block drain(left rear near the oil pressure sender) and the extra port(for a cabin heater?) up near the thermostat housing/water pump inlet. When freezing out, 15 minute preheat easilly pushes the block temp toward the 60's for an easy start...
I ALWAYS use compression release for EVERY start. There are some very good reasons to do this, particularly on the first cold start.
1. Saves wear and tear on the starter motor trying to crank past compression on the cylinders to get the engine up to speed.
2. Takes compression loads off of the rod bearings and gives the oil pressure a chance to build up and push some oil into the bearings to keep the bearing material from contacting the crank journals.
3. Sometimes things break like head gaskets and injectors, or water finds it's way down the exhaust or intake. So the potential exists that there may be fluid on top of a piston. Cranking a diesel with fluid in a cylinder can get real expensive real quick(cracked piston, bent rod, twisted crank ECT). Compression release gives the chance to clear any fluid in the engine without hopefully doing any damage to the engine...
   / My Jinma 254 has trouble starting in the cold?!?!? #7
inline heater, that is about the best thing you can do.
Thanks you guys answered my question. I did not know the glow plug position!!!<< <dummy.. I tried it this morning using the techniques described it was 47* and it fire right up after a 25 second preheat!!!
Also the block heater I have is a 1500 watt magnetic that I am goin fabricate a permanent mount for so where would be the best place to mount it?
Thanks again!!!
   / My Jinma 254 has trouble starting in the cold?!?!? #9
Magnetic heaters are very inefficient, too few of those 1500 watts actually makes it to the oil (or coolant, depending where you stick it). Expensive in terms of electricity consumption. Some lower radiator hose heaters are good (avoid Kat's), but are comparatively labor intensive to install. And I'm always afraid the do-it-yourself freeze plug heaters may arbitrarily pop out.
I personally swear by oil pan full-contact heaters. Installation of the brand I use is basically a peel-n-stick operation. None of the free air loss of a magnetic heater, easier to install than a coolant heater, cheaper to run. Depending upon which oil pan you have on that Jinma, you might be able to use one as small as 125 watts. On my larger TS354C and KM454 pans, I use 250 watts (per tractor). Keeps the oil thinned out at a nice steady 125F until you're ready to fire it up.
//greg//
   / My Jinma 254 has trouble starting in the cold?!?!? #10
I bought my inline heater from TSC, cut the line install heater tighten two clamps and that was it. I agree the magnetic heaters work, but not real well, maybe down there they'd be okay??
Yeah I used the magnetic heater on a garden tractor through the winter and it didn't do to bad it would heat the oil too around 85* or so.
The coldest I have ever seen it get down here was -10 but usually winters are fairly mild I'll give it a shot this winter and see how it does. If it isn't very efficient I will probably get a online coolant or stick on pan heater.. Thanks
   / My Jinma 254 has trouble starting in the cold?!?!? #12
Thanks again!!!
In the trash can. They are worthless. Get a lower rad heater or a glue on oil pan heater that covers more area.
My first choice would be the lower rad heater. Here in Northern Indiana where we see -30 at times my Jinma has never failed to start in 7 years now with about 45 minutes to 1 hour on the heater.
Chris
Chris
Lol mine did okay on a garden tractor but I think it probably uses more energy than it's worth. I'll look into that.
Thanks
   / My Jinma 254 has trouble starting in the cold?!?!? #14
And you did that without having to drain and refill/replace the anti-freeze. Right? And you were able to easily rotate the electrical section up into the vertical position stipulated in the instructions? Cuz those two are right up there on the complaints list compiled from folks trying to install those things correctly.
TSC sells Kats heaters, or at least they used to. If you got yours 2 or more years ago, it might still have been American made. But based up the way complaints have been piling up for the last 20 months or so, it's pretty clear that Kats has outsourced to China or Indonesia.
//greg//
   / My Jinma 254 has trouble starting in the cold?!?!? #15
Greg g; it was a couple of years back when I bought mine, but I did notice they still had one just like the one I installed on the shelf a few weeks back. I did drain the anti-freeze, it was time for a change when I added the heater. I did have one issue though, the 1st one I installed worked for about 30sec. :mad: TSC was good about it and let me get another, that has worked fine.
Does anyone know if a FEL off of a nortrac has the same mounts as a Jinma???
RonMar said:
Nortrac is a Jinma...
That's what I thought wasn't 100% sure though.. Thanks
This is an update to my original post.. I was still having issues with the tractor starting I got to looking into the problem and found that my glow plugs weren't even heating AT ALL. The post where the power wire was attached was rusty and not getting a good connection. I cleaned up one of the other posts, put on a new terminal and bolted it down, tested the connection via multimeter and I got a power reading when I turned the key to the heat position and the tractor fires up after two strokes!!! Like a champ!!! Just figured I would share the info... Thanks to all for the help!!!
Chris
   / My Jinma 254 has trouble starting in the cold?!?!? #20
Cool! Those glow plugs make quite a difference...
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
2025 BOBCAT ZT7000 MOWER (A59905)
2025 BOBCAT ZT7000...
(INOP) KUBOTA SVL 75-2 SKID STEER (A60429)
(INOP) KUBOTA SVL...
2783 (A60432)
2783 (A60432)
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
