URGENT NEED!
   / URGENT NEED! #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Can anyone help me out on where I might find a set of forks for the pin type quick attach for my 6000? I do not want to have to hire someone else to help with the poultyr house cleanout.
   / URGENT NEED! #2
Have you checked your local Mahindra dealer. I'm sure he can order them for you.
   / URGENT NEED! #3
Are you looking for pallet forks or manure forks?
   / URGENT NEED!
He has been ordering me a set for about a year! According to him Mahindra doesn't offer them anymore for that pin on type quick attach. They had sub contracted that out to a company and he was going to try to get them from that company. That was a year ago and I never heard anything else.
   / URGENT NEED!
Not sure of the difference, but I need something to lift a 4ft by 14ft poultry house slat. In years past I have moved them with the pallet forks on the 7010. Not happening this year :(
   / URGENT NEED! #6
Are you talking standard skid steer QA ??
   / URGENT NEED! #7
Buy a set of cheap or used skid-steer forks and have a local welder modify them to fit.
   / URGENT NEED! #8
Isn't there a sponser the on here, something like everytthingattachments.com?
Check the list of sponsers.
As mentioned, get a set and have a welder modify.
   / URGENT NEED! #10
I am not familiar with your pin type quick attach, perhaps one of these would work?
Tractor Pallet Forks Quick Attach
Another thought, perhaps you can find a skid steer quick attach for your loader, then you can use standard SSQA?
Local metal shop should be able to adapt a set of used pallet forks pretty reasonable.
   / URGENT NEED! #11
If I am not mistaken, your loader is a ML264, made by Bush Hog not KMW. I found one of the last sets available at Bush Hog a couple of years ago, for a customer here on TBN. After I did all of the leg work he got them through his local dealer, less shipping. At that point the Bush Hog didn't intend to build anymore. Fabrication may be your only option.
   / URGENT NEED!
Actually I think mine is a Great Bend loader. It is one of the first 6000s made. At the time it was the biggest Mahindra had here in the states.
I'm needing them like tomorrow so fabrication isn't really an option. I had been told I would have the 7010, but that's not gonna be happening. It's split at this point.
   / URGENT NEED! #13
In my way of thinking, if you need them that fast then fabrication is your ONLY option. Get a set of skid-steer (SSQA) forks have have them modified to fit locally.
Can you be more specific as to your location? Maybe someone close to you can help. I would.
   / URGENT NEED! #14
I'm still confused as to "Pin Type" QA ... is he refering to the Skid Steere QA ??
His profile shows he's in the Welfare Capital of the world ... heck he must be my neighbor!!
   / URGENT NEED! #15
I'm pretty sure your '04 6000 has a KMW loader...my 6000 is an '02 and has a KMW...if it is there is a KMW sticker somewhere on the left side (left looking from seat) saying so..Note: Bush Hog never put a loader on a Mahindra...Great Bend did...and was subsequently bought out by Bush Hog..(as well as I remember). RBACK works/used to work for KMW...maybe he can shed some light on it. BobG in VA
   / URGENT NEED! #16
I made a set of forks from a skidsteer "cover" set (the kind that slip over a worn set)..I'll try and post a couple of pics..BobG
   / URGENT NEED! #17
I know JD offers a pin type QA on their 5045/55D tractors. Not saying it's compatible but if you have a dealer nearby, might be worth a call.
   / URGENT NEED!
Hit pay dirt today. There happened to be some forks that would work on a set at my dealer. They will be floating like the originals. Think he said Tennessee River Metals made them.
Loader is definately a great bend. I found some old paperwork that says so.
Found the perfect set, but they cost $40000. They were attached to an 8560 cab!
   / URGENT NEED! #19
I'm sorry sometimes the memory portion of my brain doesn't function properly. You are correct it was Great Bend, but I am maybe thinking they were bought up by Bush Hog. It just seams to me that Bush Hog is where I found that set of forks.
Any how I am glad that you found forks that will work, good luck.
   / URGENT NEED! #20
OK Joel, you had said that 42K was a good figure for you, and now you have one down to 40K. We are going to be expecting some pictures and a report very soon. :laughing: ;) By chance did you have a chance to check out the 8560? I was wondering what you thought about it. :drool:
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
19008 (A56859)
19008 (A56859)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 6120M (A57148)
John Deere 6120M...
CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
CATERPILLAR M322D...
