Anyone ever straighten a twisted FEL?
/ Anyone ever straighten a twisted FEL? #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
This is setting on conrete ... no visable damage. She is obviously out of wack.
/ Anyone ever straighten a twisted FEL? #2
Tractor make/ model, fel model? All the above would help figure out what to do.
Branson 5530 with a BL30B FEL
/ Anyone ever straighten a twisted FEL? #4
I'm not familiar with that particular setup, but I think if you post some more photos of the area that holds the loader to the frame it might help diagnose what is causing the skewed bucket situation. FWIW, I had a similar problem with my DK-35 Kioti which is posted in the Kioti forum. My eventual solution was to upgrade the tractor/bucket to a heavier duty model. That may not be your solution- so check out the thread I posted to see if any of it applies to your situation.
Thanks..I'll try to find your post. I can not see any visable bends, breaks, cracks or the like.
It appears to be in the very front of the two loader arms where the pipe connects across. When its raised to just about the hood level its definatly out of wack.
I believe the left went down.
/ Anyone ever straighten a twisted FEL? #6
By chance do you have hooks on the very outer end of the bucket?
If so, a heavy load on one of them may have twisted the loader arms themselves.
Sounds like that happens more often than we know
/ Anyone ever straighten a twisted FEL? #7
http://www.tractorbynet.com/forums/.../161951-front-end-loader-pistons-housing.html
Above is the link to my original post about having bent my loader arm pistons/cylinders; which were temporarily fixed by adding new, and later reinforcing the new 1/2 moon arched plates and doing a bunch of welding of bent stops etc. Thing is, it all occurred again in short order probably as a result of my use, and IMHO the poor quality design of the bucket/ loader arms; pertaining to the strength of the loader to do what the bucket, operator and tractor are capable of- which is beyond the loader's ability to support the bucket's capability.
/ Anyone ever straighten a twisted FEL? #8
Everyone expects the tractor is at fault. Are you sure that concrete's level? :D
Yes the concrete is level. You can even see the difference when the hay fork is on.
Yes hooks on each side ...
/ Anyone ever straighten a twisted FEL? #11
Is the left side of your loader your favored slicing edge?
/ Anyone ever straighten a twisted FEL? #12
Before I would do anything, I would start measuring everything closely, including air pressure and especially axle height front and rear. Remove all varibles before you start or it will still be wrong when you get it "straight".
David from jax
/ Anyone ever straighten a twisted FEL? #13
You might look all the way back to the mid point of the tractor to make sure it is not all in the bucket.
The bucket does not looked abused.
The bucket is on for reference ... its visable even with out the bucket. When your in the cab and raise the FEL you can look over the hood and see one side is lower (or maybe one side is higher)
David from jax
Thanks for the advise. Seems as though I have gone over and over this thing with the same concerns you share. I have concluded its in the arms. They have got to have a twist in them.
/ Anyone ever straighten a twisted FEL? #16
Several years ago, we (brothers and I) twisted a FEL trying to pick up some iron scrap up out of the dirt that had buried itself over time. It was twisted pretty bad, if I recall. Bad enough that we could tell it was out of whack out the moment we caused it. We straigtened it out against a tree by carefully driving the leading edge against a tree. Back then, the tree, FEL, and we survived. I'm not sure I would try the same fix today, but I know it is possible.
/ Anyone ever straighten a twisted FEL? #17
And do the tires on each axle have the correct and equal pressure? No excessive tire wear on one side or the other?
If that's all good, then like was suggested start making precise measurements to find out where the difference is. If your loader can be removed, I would start there by parking the FEL on a level concrete pad, if you can. Measure the main support brackets bolted to the sides of the engine/chassis. See if they are equal heights. If the loader by itself still sits unlevel on a level pad, then you know the problem is at least in the loader arms and/or bucket, but you could still have some differences with the main support brackets. Good luck, hope you figure it out and get it straightened out!
/ Anyone ever straighten a twisted FEL? #18
I have done a few of these in my body shop.
It's pretty easy, if you have the right set up.
I would talk to your local shop, and see if they are interested in the job.
This is usually the slow season; they might make you a fair offer.
Tires have equal pressure and equal wear. Removing the FEL ...thats my next step .. it is a QA so I am going to take it off and do more measuring with it setting on the concrete slab.
I here ya ... thoughts are going in and out of my mind. Chains, hydraulics, bending, pushing, pulling ... Ramming a tree in C4 (seat belted in) ... no just kidding ... did think about it though!!
They seem to straighten car frames ... there has got to be a solution to get this thing tweeked back into shape.
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
FUTURE MB27-27" HYD MIXING BUCKET (A60432)
FUTURE MB27-27"...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
