4320 cab and 8' garage door
   / 4320 cab and 8' garage door #1
Rockgod
CNY
JD X380 Accel 48" Deep Deck
Will a 4320 w/cab and R-4's fit in a garage with 8' tall doors? From the search button I've discovered that the 3x20's will. But will the larger Deere sneak in?
Has anyone physically done it?
   / 4320 cab and 8' garage door #2
I couldn't find that information on the JD website. It would be a close call. I suggest you call a JD dealer and he should be able to determine the height with cab.
   / 4320 cab and 8' garage door #3
I doubt it. I'm not at home, so I cant take a tape to my garage doors, but my open station 4720 doesn't fit without dropping the ROPS.
-Jer.
   / 4320 cab and 8' garage door #4
A 4320 open station with ROPS up will not fit (97 inches), so doubt a cab would.
I asked him, he wasn't sure.
I've heard that it's 94.5" to the top of the cab.
Was wondering if someone actually tried it. :D
   / 4320 cab and 8' garage door #6
This is from the 4x20 operator manual. Does not list R4 height, but does show significance of tire size.
Height From Ground (Tractor without cab, with standard R1 tires)
To Top of Folding ROPS 2.5 m (97.2 in.)
Height From Ground (Tractor with Cab, R3 tires)
To Top of Cab 2.35 m (92.4 in.)
   / 4320 cab and 8' garage door #7
I just went out and put a 2x4 across the top of the cab of my 4520 with R4s. At the rear axle, I measured 94.5".
It's close enough that I'd go measure one yourself, then measure your actual garage door opening. It might be an 8' opening when framed, but how much was lost to the trim and door seal? Hopefully the ground is level with the garage so there's no angling going on either.
I put 8' 6" doors in my garage. At the house I specified 8' 6" doors but the architect blew it, so I have 8' 3". Still enough for the 4520, I've had it in there.
Measure 3 times, buy once :laughing:.
Pete
   / 4320 cab and 8' garage door #8
Duuuurrrggghhh!!! :mad:
Did you get a discount on his 300$ per hour rate?? :cool:
-Jer.
Pete
From the floor to the bottom of the trim piece it measures 95.5".... And yes there is a slight incline.
Thanks for the measurement :D
   / 4320 cab and 8' garage door #10
jgrreed, don't get me started on the architect. Everyone I meet who is thinking of building a house, I bring them over and by the time I'm done with them there's no architect in their plans.
Rockgod, OK on your measurement, not to be insulting but in the interest of avoiding "architect class" errors, the door goes all the way up and a tiny bit then some?
It's odd that Deere made the rops 1.2 inches over 8 feet, but made the cab 1.5 inches under. I wonder if, since open station came 1st, they realized they were close and got it on the cab. Well, at least I can dream that when things work out is was by plan and not chance :laughing:.
You might be able to get the dealer to agree (in whatever form works for you) that the 4320 will fit in given your 95.5" clearance, and that if it doesn't you can return the tractor for a full refund. That would let you order with piece of mind.
Pete
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
JOHN DEERE 8R 340 LOT NUMBER 96 (A53084)
JOHN DEERE 8R 340...
FAKE (A52472)
FAKE (A52472)
New Wolverine Hydraulic Shift Pallet Forks (A51573)
New Wolverine...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
