home build 40 Ton hydr press
   / home build 40 Ton hydr press #1
Bison
Near Peace river -Alberta
ASV 4810
I build this hydr press a couple yrs ago from stuff i had laying around.
Only things i bought new was the soleniod valve and remote hand control + hydr hoses.
the cylinder is 6" x 12" stroke.
i used a 2 hp electr motor to drive the pump.
I don't know how i ever lived without it before
   / home build 40 Ton hydr press #2
Nice work. I would like some more details on the pump and such. :thumbsup:
Took some more pic's for ye.
The pump is a small volume webster,5000 psi max press. it is set at 4500.The 2 hp is 220v
   / home build 40 Ton hydr press #4
I have kicked that idea around and the only part I don't like is tripping over the legs to stabilize the press. Plus they do take up some room and are not very portable. One of these days I will find a design that will work better for my situation.
   / home build 40 Ton hydr press #5
Nice press. What size of channel is that?
   / home build 40 Ton hydr press #7
Cool. How'd you punch the holes for the work table pins?
JayC
I drilled pilot holes,clamped an old brg race with the proper size hole in it welded to a piece of angle iron as a guide for the torch to the channel and cut them to size with the torch,then finnishid up with a grinding cone on the angle grinder.
   / home build 40 Ton hydr press #9
I like that idea.
Is your pins heat treated, or just shafts out of something you had? (the bed)
   / home build 40 Ton hydr press #10
A six inch cylinder @ 4500 psi has 63.6 tons of push. That's getting into some serious force! :eek: I can't tell from the pics, but is the ram free to travel from side to side?
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
MARTIN - SET OF 12 COULTER MOUNT MARTIN ROW CLEANERS (A52748)
MARTIN - SET OF 12...
