Compact tractor with highest road speed ?
   / Compact tractor with highest road speed ? #11
My Farmall 40 CVT goes 21.8 mph according to speedo and gps on pavement.
   / Compact tractor with highest road speed ? #12
I do not know your situation,but if you have just home owners insurance on that tractor,you may not be covered if you have an accident. I gave up my farm insurance when I retired. I save a lot of money,unless I have an accident off of my property.
As far as your question,my Montana U4984 according to the specs goes just a little over 19 MPH.
   / Compact tractor with highest road speed ? #13
My NH TC40D is listed for 13.6mph top speed.
I have drivien it 3 miles. It was interesting hugging the side of the road, staying out of traffice on one road, and going 13.5mph. It was, easier than going home and getting the trailer. Needless to say, I brought it home from the same property yesterday. I trailered it. Even though it definitley took longer to get the trailer, go over, load the trailer, get home, unload the trailer, put the trailer away...
This tractor, my previous one, and even my old Farmall-A, were a handfull at top speed.
Seriously, get a trailer. Besides, the trailer will become one of you best tools; I use mine all the time. I get probably a 10:1 ratio, of using the trailer for other stuff(hauled car, Bronco, hay, pipe, lumber, concrete block, firewood ect ect ect...).
The route from my freinds to home, where I was yesterday, has about a mile of busy road. When that first big rig goes by you, it'll make you think twice. Especiallt at 50-55mph...
The other thing, when I got this newer tractor(got it used), I asked the shop guy how much my rear tires would cost. He said they start at about $600/ea... :eek:
   / Compact tractor with highest road speed ? #14
Back when I was a teen on the farm I got to drive our 1850 Cockshutt about 85 miles @ the breathaking speed of 15.6 mph. Long trip! :D
   / Compact tractor with highest road speed ? #15
i would wont to tow any tractor down the road behind a pick to much to can go wrong that could cost more to fix than a trailer would cost
The TC30 weighs 2200 lbs per specs I read. When in Hi school I towed a Ford 8N all summer behind a 1/2 ton pick-up to do mowing on township roads. It was an easy tow. Had a strong solid tow bar complete with safety chains. Probably accumulated 500 miles. The 8N weighs more than the TC30. (about 2400 lbs) I had a 5' bushog on the back for 500 more pounds. Add a mid mount sickle mower for another 400 lbs. Granted I wouldn't get on major roads, not because I would be afraid of the tow, but because of the other crazy bastards running 75 & 80 MPH and me running 25-30.
Add 12-1500 lbs for a trailer and now you are pulling and stopping 3500 lbs. If a tractor won't pull straight, adjust it so it will. If a tractor won't go straight down the road at 25 MPH, I would rather be in the cab of my pick up pulling it than driving the tractor.
My experience is from late 50's and early 60's and things have changed a lot with liabilities and etc. The reason we did business as we did was purely economics.
I probably read something into the original post that I shouldn't have. The original post stated he did not want a trailer. I would not want to trade tractors to get another 10 MPH, but if the poster wants a different/new tractor, I guess that reason is as good as any.
   / Compact tractor with highest road speed ? #16
I am pretty sure my IH goes 20 MPH.
my father told me years ago that he would put a FEL bucket in the back of a small dump body and then lift the front end of the tractor off the ground. Strap the bucket down and tow it that way. This was before i was around not sure how safe that was.
I think the money you save you will spend on new tires on that tractor.
   / Compact tractor with highest road speed ? #17
That's a poor boy 5th wheel.
Those trailers have tires too. I seem to have more trouble with trailer tires than tractor tires. At least they are cheaper. Maybe I should have said less expensive or maybe cheap is my real problem.
   / Compact tractor with highest road speed ? #18
i routinely road my ford 5000 or NH 7610s ( 70 and 95 hp tractors ) down the road with 10' and 15' mowers on them... however these are larger tractors with rops and all.. I feel fairly safe as I'm bigger than most passanger traffic... I'm not sure if I'd want to do it with a small CUT.
I have a 4000 4 cyl with a sherman overdrive and I've had her near 20 using my wifes gps as a speedo. was white knuckly a bit... metal pan seat, no rops.. and no foot throttle, plus 'steering brakes' :)
I run probably 18mph down the road inthe larger ones. kinda a nice drive if you don't do it often
soundguy
   / Compact tractor with highest road speed ? #19
My new LS P7010 will do more than 20 MPH on the road but it is not a compact. I have only had it on the road once just to see how fast it would go. The roads at my farm are rather narrow for 2 cars to pass and lots of curves and narrow bridges. I would not want to drive far at all on those roads with my tractor. I would not like for someone to run into me even though I think they would suffer most of the damage.
   / Compact tractor with highest road speed ? #20
I own a NH tc30 with 30 hp and want to upgrade to something in the 35 to 40 hp range. I have about 10 miles between food plots and I don't want to buy a trailer. Which compact tractor has the highest top speed ? It woud be nice to find one that would go 20 plus mph. Thanks !
Too many little things can go wrong at higher speeds---14MPH +) that get magnified on a tractor. High probability of an unhappy and likely uninsured ending. Go to Plan B. Could even be a drive-on trailer with a tilt bed that drops down when you drive on it to make it real simple.
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
John Deere Bale Spear (A55218)
John Deere Bale...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
