SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,388
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Perhaps we should revisit a previous thread where a lot of effort went into getting the truth out:Raising it HIGHER does NOT require more force. In fact, the very geometry you guys are going on about makes it EASIER to raise the ball as it goes higher than the ball eyes. Why? Because as the ball goes higher than the pins, the 3pt arms bottom attachment point starts to take some of the weight of the object. So there is LESS mass for the hydraulics to lift at the higher points. Its the LOWEST point that requires the most lift force because its the only position in which the hydraulics are lifting the entire mass of the object. And again, the toplink has nothing to do with it other than changing the angles of attack.
http://www.tractorbynet.com/forums/buying-pricing-comparisons/145738-conversion-factor-3-point-hitch.html
